iLogic code to toggle "edit dimension when created"
DeepshipEngineering
DeepshipEngineering
See attached video.  I have created macros to change the drawing standard for different decimal places and dual units but I would like to add another macro to toggle the check box, "edit dimension when created", ideally a see through command I can run whilst in the dimension command
TIA
Michael.Navara
You are looking for this setting in DrawingOptions
'Store current setting
Dim editDimension = ThisApplication.DrawingOptions.EditDimensionWhenCreated
'Disable edit
ThisApplication.DrawingOptions.EditDimensionWhenCreated = False
'Do something. In this case I just call standard command for dimension
ThisApplication.CommandManager.ControlDefinitions("DrawingGeneralDimensionCmd").Execute2(true)
'Set previous value back
ThisApplication.DrawingOptions.EditDimensionWhenCreated = editDimension
DeepshipEngineering
Thanks for the reply.  Lines 1 to 5 work great for tuning edit dimension when created off.  Would there be a way of checking if its on or off and using the rule to toggle it to the opposite? I know there would be no feedback on the macro button to tell you which state was active but think we could live with that
Michael.Navara
You want just so switch the value?
You can use this
ThisApplication.DrawingOptions.EditDimensionWhenCreated = Not ThisApplication.DrawingOptions.EditDimensionWhenCreated
