Ilogic code to suppress a user created work point/workplane
jayanthi_sara
Observer Observer
jayanthi_sara
Observer
Observer
Hello all,
I need to automate the drawings using Ilogic code,
In order to do this, I need to suppress some of the user created work point/work planes, which I have used for creating dimensions through ilogic code.
cidhelp
Hello @jayanthi_sara ,
do you mean workpoints that are used in drawingviews to create drawing dimensions?
Then you can start at the dimension and get IntentOne/IntentTwo.Geometry (these are CenterMarks-objects). Set Visible = False for these Centermarks.
If oDim is the LinearGeneralDimension then:
oDim.IntentOne.Geometry.Visible = False
oDim.IntentTwo.Geometry.Visible = False
switches off the visibility of the centermarks.
