ilogic code to remove the linked file from parameter of a .ipt or .iam
nowell.colsenXK53F
nowell.colsenXK53F
looking for an ilogic code to remove the linked file from parameter of a .ipt or .iam that has been linked. Looking for a fast way to unlink .ipt or .iam from there linked part. The master file that is linked is itself a .ipt file
m_baczewski
I'm sending a short piece of code that shows how to remove all linked files from an assembly file. Is this exactly what you were looking for? Or do you want to go through the entire assembly and remove them from all parts and subassemblies?
Sub main()
	Dim oDoc As AssemblyDocument = ThisDoc.Document
	Dim oAssemblyCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oParams As Parameters = oAssemblyCompDef.Parameters
	Dim oDerviedParamsTables As DerivedParameterTables = oParams.DerivedParameterTables
	For Each oDerivedParamTable As DerivedParameterTable In oDerviedParamsTables
		oDerivedParamTable.Delete()
	Next
End Sub
nowell.colsenXK53F
Yes and no, the main linked file is an .ipt, the files its link to is either a .ipt or .iam.  but what you sent I think I can rewrite it to work in both .ipt or iam file. My main goal is to remove all links from the user parameters then delete the linked file, So I dont end up with new user Parameters with _1. if that makes sense?
mateusz_baczewski
I understand you but i need ane example. Can you send a small example of a part or assembly to show how it looks?
It seems to me that if you delete linked files and a part/assembly uses parameters from that linked file, then after removing those files, parameters with the same names are automatically created. Unless the linked files have parameters with the same names, in which case "_1" is added to the parameter name.
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
