ILogic code to reference Windows login name
jmfowler1996
Message 1 of 12
jmfowler1996
Hi.
I have been making some adjustments to our company drawing template.
One thing which I have become fond of is the idea of having an iLogic form with many useful links to file locations et cetera.
I am currently making one of such shortcuts; this one for the user's scanner file.
The location of the file is as follows, using my name, Jonathan Fowler, as an example:
\\HDSDC02\Scanner\Jonathan.Fowler
I have come up with the following code:
MyName = ?
ScannerLocation = ("\\HDSDC02\Scanner\" & Left(MyName, InStrRev(MyName, " ")-1) & "." & Right(MyName, Len(MyName)-InStrRev(MyName, " ")))
ThisDoc.Launch(ScannerLocation)
It works, however, the MyName variable has no value.
I need a way to set this variable to be my Windows login name (Jonathan Fowler).
I have tried
MyName = Environ("Username")
and
MyName = ThisApplication.UserName
 , but both of these result in an abbreviated form of the user's name. In my case, it is jfowler.
If you know any way of referencing the Window's login name using iLogic, I would be very grateful if you could share it.
Many thanks,
[MyName]
Replies (11)
Message 2 of 12
mcgyvr
How about this?
Its not the Windows login name but rather the username from tools..application options..general tab
No idea if ilogic can pull the actual Windows username
SyntaxEditor Code Snippet
'get the user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
Message 3 of 12
jmfowler1996
Thanks, but unfortunately, this returns a value of "jfowler" in my case, whereas I am looking for my full name, "Jonathan Fowler", so that I can use it in the file location.
Message 4 of 12
Curtis_Waguespack
Hi jmfowler1996,
Give this a try:
WSHnet = CreateObject("WScript.Network")
UserName = WSHnet.UserName
UserDomain = WSHnet.UserDomain
objUser = GetObject("WinNT://" & UserDomain & "/" & UserName & ",user")
'get user name
UserFullName = objUser.FullName
'remove space and replace with dot
oDotUserName = Replace(UserFullName," ",".")
'return both variations
MessageBox.Show( "Full User Name: " & vbCrLf & UserFullName & vbCrLf & oDotUserName, "iLogic")
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Message 5 of 12
jmfowler1996
Thanks, Curtis.
That's much appreciated.
This worked perfectly for me and I am definately going to have a long look at this to understand how you got to that solution. 'Grats.
I'll check out that other forum too.
Ta!
Message 6 of 12
mcgyvr
@jmfowler1996 wrote:
Thanks, Curtis.
Ta!
Its vb stuff it seems.. I learn so much from the code Curtis can write.. I would love to be able to do it like that just don't have the time to sit down and figure it all out..
But here..
https://msdn.microsoft.com/en-us/library/s6wt333f(v=vs.84).aspx
Message 7 of 12
Curtis_Waguespack
Hi jmfowler1996,
mcgyvr makes a good point. iLogic is a tool set that has it's own limited set of functions and calls, but you can mix in VBA and VB.NET code as well. I almost never write pure iLogic, and have probably confused a few people over the years by not making the distinction between ilogic, VBA and VB.NET.
I hope this helps.
Curtis
Message 8 of 12
dusan.naus.trz
@Curtis_Waguespack
Hi, If I have a PC at home, then your code does not work = it says ActiveX component cannot be created. Is it possible to make it work somehow? If I have my PC connected at work, then your code works.
Message 9 of 12
petHYD9W
Observer
Observer
Any answers?
Message 10 of 12
dusan.naus.trz
Hello. I didn't get an answer. I am not using the code above. I used a different code and it works for me.
myName = ThisApplication.GeneralOptions.UserName
Dim myNumber As String
myNumber = "myPCName"
Message 11 of 12
Curtis_Waguespack
@dusan.naus.trz @petHYD9W
edit: oops, sorry I answered the wrong question
You might try this :
sComputerName = Environ$("computername")
MsgBox(sComputerName,,"iLogic")
Try this:
sUserName = Environ$("UserName")
MsgBox(sUserName,,"iLogic")
or this
sUserName = System.Windows.Forms.SystemInformation.UserName
Message 12 of 12
Frederick_Law
It get User Name from Inventor.  Enter whatever you want here.
