iLOGIC Code to Recognize Sheet Number
SECOJOSE
SECOJOSE
I have ilogic in a drawing that selects the model state of a drawing view, and the code that i use is dependent on the sheet number to specify the view. Is there code that returns the value of the sheet based on the name of the sheet? Or is there a way to reference a drawing view that is not dependent on the sheet number? The line im using for view selection:
ThisDrawing.Sheets.ItemByName("SHEET NAME:1").View("VIEW NAME").View.SetActiveModelState(...
A.Acheson
Hi @SECOJOSE
If you just want to select a view manually and set modelstate use the pick function from the Inventor API
Dim drawView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view")
	drawView.SetActiveModelState("ModelState")
If you want to get the active sheet then use iLogic API
ThisDrawing.ActiveSheet
Regards
Alan
WCrihfield
Here is a commonly used tactic to separate the sheet name and the sheet number, if needed.  It gets the value of the Sheet.Name property, then uses the vb.net Split() method on it, using the ":" character as the separator, to get an Array of Strings.  Then either gets the first String in that array, as its pure name, or gets the last String in that array as the sheet's number, then converts that numerical String into an Integer, using the CInt() converter function.  Then just shows you the result in a simple MsgBox call
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
Dim sSheetName As String = oSheet.Name.Split(":").First
Dim iSheetNumber As Integer = CInt(oSheet.Name.Split(":").Last)
MsgBox("Active Sheet Name = " & sSheetName _
& vbCrLf & "Active Sheet Number = " & iSheetNumber.ToString, vbInformation,"iLogic")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
