iLogic code to export ALL iParts as DXF with Different Layers
Hi all,
With the help of some forum searching and other posts I've made, I found this link: https://clintbrown.co.uk/2021/01/13/ilogic-export-flat-patterns-of-ipart-members-to-dxf/ to almost solve my problem. The iLogic code in that link exports all flat patterns as a .DXF which is great, but I would like to have it such that the geometry and sketches get exported in different layers for cutting and marking respectively. I know its possible in SolidWorks, but it isn't automated, meaning id have to go 1 by 1 for 400+ parts a day...
In short, I am looking for assistance in modifying or adding onto this code to export all flat patters, with geometry and sketches on different layers. Thank you in advance!
JelteDeJong
For exporting geometry on a different layer you dont need to add extra code. But you need to add attributes to add to the geometry that you want exported on a other layer. That cant be done with standard Inventor tools. But it can be done with an iLogic rule or an addin. I wrote a blog post about that and can be found here
Jelte de Jong
Blog: hjalte.nl - github.com
