iLogic Code to Delete Specific Parameter in all Parts Within Assembly
Cadderman
Cadderman
Hi all,
I'm not particularly good at producing iLogic codes - I need what I think should be quite a simple code...
I need to delete the parameter "Thickness" in all components within an assembly.
Any help would be greatly appreciated.
Curtis_Waguespack
Hi @Cadderman, something like this should work. Hope that helps, Curtis
Sub Main
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	Call TraverseAssembly(oOccs)
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		If oOcc.Suppressed = True Then Continue For
		'get the document from the occurrence
		Dim oDoc = oOcc.Definition.Document
		Try
			oDoc.ComponentDefinition.Parameters.Item("Thickness").Delete
			Logger.Info(oOcc.Name & " parameter deleted")
		Catch
			Logger.Info(oOcc.Name & " could not find or delete parameter")
		End Try
		'if assembly loop back up and step down into it's occurrences
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Call TraverseAssembly(oOcc.SubOccurrences)
		Else
			' handle stuff for just parts here if needed
	Next
End Function
Cadderman
Perfect, thanks @Curtis_Waguespack ! Much appreciated
