I am new to ilogic and can only write simple codes, so i hope someone can help me.
I am trying to write a code that would toggle supression of multiple model folders via a text parameter.
I've done it using all the parts within the folders but it would be much easier if i could supress the entire folder in one line. This is how i have written it out.
If SK10_Size = "55kW" Then Component.IsActive("D130000260174 SK10 55kW:1") = True Component.IsActive("D130000260174 SK10 55kW:2") = True Component.IsActive("D130000260175 SK10 75kW:1") = False Component.IsActive("D130000260175 SK10 75kW:2") = False Component.IsActive("D130000260176 SK10 90 kW:1") = False Component.IsActive("D130000260176 SK10 90 kW:2") = False Else If SK10_Size = "75kW" Then Component.IsActive("D130000260174 SK10 55kW:1") = False Component.IsActive("D130000260174 SK10 55kW:2") = False Component.IsActive("D130000260175 SK10 75kW:1") = True Component.IsActive("D130000260175 SK10 75kW:2") = True Component.IsActive("D130000260176 SK10 90 kW:1") = False Component.IsActive("D130000260176 SK10 90 kW:2") = False Else If SK10_Size = "90kW" Then Component.IsActive("D130000260174 SK10 55kW:1") = False Component.IsActive("D130000260174 SK10 55kW:2") = False Component.IsActive("D130000260175 SK10 75kW:1") = False Component.IsActive("D130000260175 SK10 75kW:2") = False Component.IsActive("D130000260176 SK10 90 kW:1") = True Component.IsActive("D130000260176 SK10 90 kW:2") = True End If
