iLogic code that returns the occurrences of a part
DSilver4773
DSilver4773
I have an assembly that consists of 2 parts that are each used twice to make up my assembly. I am writing some ilogic code that then takes the active assembly and generates step files for the assembly along with the individual parts. The issue I am having is when I save the individual parts I want to save one occurrence as xxx-Outer and the other occurrence as  xxx-Inner for each part type. Is there a way to do this in iLogic?
chandra.shekar.g
Autodesk Support
Autodesk Support
@DSilver4773,
Hoping that suggestions in the below blog link may be helpful.
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
