iLogic Code runs only once per drawing file
rnandan
Message 1 of 12
rnandan
I am attempting to update the font and font size of a general note object in a drawing. The note contains text in different fonts and sizes.
From the code below I was able to change it once. I retried the code with a different font and size but the text format does not change.
It works on a different drawing though, but exactly once. I'm new to writing iLogic, so not sure what basic thing I'm missing.
Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
Dim oPickedDrawingNote As Inventor.DrawingNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingNoteFilter, "Select text")
'oPickedDrawingNote.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
Dim eText As String = oPickedDrawingNote.FormattedText
oPickedDrawingNote.FormattedText = "<StyleOverride Font='Tahoma' FontSize='0.12*2.54' Bold='False' Underline='False'>" & eText & "</StyleOverride>"
oDrawDoc.Update()
Replies (11)
Message 2 of 12
Curtis_W
@rnandan, I think you just want to use the Text rather than FormatedText for this line, and everything else can stay the same.
Hope that helps, Curtis
Dim eText As String = oPickedDrawingNote.Text
Message 3 of 12
Curtis_W
If you want to have a toggle, you can use something like this:
While True
	Dim oPickedDrawingNote As Inventor.DrawingNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingNoteFilter, "Select text (ESC to continue)")
	If IsNothing(oPickedDrawingNote) Then Exit While
	Logger.Info(oPickedDrawingNote.FormattedText)
	If oPickedDrawingNote.FormattedText.Contains("Tahoma") Then
		oPickedDrawingNote.FormattedText = "<StyleOverride Font='Segoe Print' FontSize='0.12*2.54' Bold='False' Underline='False'>" & eText & "</StyleOverride>"
	Else 'if it's anything else, format like this:
	oDrawDoc.Update()
End while
Note too the logger line output might be something to be aware of, for seeing the formatting, etc.
See link for info about using the logger if that's new to you:
https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-BE996AA3-DE49-4765-86A7-129DD7B42A4A
Message 4 of 12
rnandan
I changed the declaration for eText to Text rather than FormattedText. The code runs and changes the Font and size reliably but now all the break lines are gone. The multiline text is just one single line.
oPickedDrawingNote.FormattedText = "<StyleOverride Font='Tahoma' FontSize='0.3' Bold='False' Underline='False'>" & eText & "</StyleOverride>"
Out of curiosity I tried the following as well where the FormattedText was swapped. The result was that the fonts and font size changed every time, but the textbox now contained the xml tags as well and one single line again.
oPickedDrawingNote.Text = "<StyleOverride Font='Tahoma' FontSize='0.3' Bold='False' Underline='False'>" & eText & "</StyleOverride>"
So. my observation is that "FormattedText" cannot come consecutively. I'm curious to know why.
Message 5 of 12
jnowel
For a single line text (w/o any StyleOverrides), the "oPickedDrawingNote.Text" and "oPickedDrawingNote.FormattedText" is the same
That is the reason why your code initially works the first time. After the code ran, Text and FormattedText won't be the same anymore
For multi-line text (w/o any StyleOverrides), the "oPickedDrawingNote.Text" and "oPickedDrawingNote.FormattedText" is NOT the same .
FormattedText has additional line breaks "<Br\> inside that isn't shown in Text property.
As for a solution, you can try below code
	'Logger.Info("Method2")
	Logger.Info(eText)
	'Remove All the styleoverrides
	Dim sText As String() = eText.Split("<StyleOverride ", StringSplitOptions.RemoveEmptyEntries)
	For Each subText In sText
		Dim sOldStyle As String = Left(subText, InStr(subText, ">") -1)
		eText = eText.Replace("<StyleOverride " & sOldStyle & ">", String.Empty)
		eText = eText.Replace("</StyleOverride>", String.Empty)
	Next
	'Apply New Style Overrides
I'm not too much familiar with the XML formatting, but it seems it is smart enough to apply the styleoverrides after the line breaks.
as an example:
the Formatted text of that is
TEXT<Br/>TEST
after the rule, the expected value of the FormattedText is
<StyleOverride Font='Tahoma' FontSize='0.3' Bold='False' Underline='False'>TEXT<Br/>TEST</StyleOverride>
but surprising enough, the FormattedText Property is able to "correct" it to
<StyleOverride Font='Tahoma' FontSize='0.3'>TEXT</StyleOverride><Br/><StyleOverride Font='Tahoma' FontSize='0.3'>TEST</StyleOverride>
btw, I think it cannot do math expressions for the font size in XML format directly. so have to separate it (or just assign the computed value)
so instead of doing it as
do it as
oPickedDrawingNote.FormattedText = "<StyleOverride Font='Tahoma' FontSize='" & 0.12*2.54 & "' Bold='False' Underline='False'>" & eText & "</StyleOverride>"
Message 6 of 12
rnandan
Hi jnowel,
The code returned a compile error.
Error on Line 9 : Argument matching parameter 'separator' narrows from 'String' to '1-dimensional array of Char'.
Message 7 of 12
jnowel
weird, it's working on my end w/o issues in Inventor 2026
anyway, try this instead
'Logger.Info(eText)
'Dim sText As String() = eText.Split("<StyleOverride ", StringSplitOptions.RemoveEmptyEntries)
Dim sText As String() = eText.Split("<StyleOverride ")
	If InStr(subText, ">") < 1 Then Continue For
Next
@rnandan can you check this new line12
Message 8 of 12
rnandan
I'm on Inventor 2024. The new code gave an error on line 13
Argument 'Length' must be greater or equal to zero.
Message 9 of 12
jnowel
weird. i though the current line12 will prevent that issue on line13.
can you send me the idw/dwg just to check what i missed?
anyway, i'll edit line12 to a different one in a minute
Message 10 of 12
Curtis_W
@jnowel wrote:
I'm not too much familiar with the XML formatting...
@jnowel, in case it's helpful you can find some info for this online here:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-915B75BA-4696-4fc7-A2C6-54B2BACDE7E1
Or you can find the same reference material, but a bit easier to read in your local API help by searching the API help for "Text Tags" or "XML Tags for FormattedText", etc.
Message 11 of 12
Curtis_W
@rnandan , here is a version of @jnowel's code with some logger lines, this might help you determine what the issue is with line 13 ?
iLogic Logger reference: https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-BE996AA3-DE49-4765-86A7-129DD7B42A4A
'Logger.Info(eText)
Logger.Info(sText.Length & " items in the split array:")
	Logger.Info(subText)
Next
Message 12 of 12
jnowel
I think i figured out why my previous line12 introduced some errors.
i only considered empty strings as the other values of subText which isn't the case
If Len(subText) < 1 Then Continue For
a single line with a combination of no styleoverride and styleoverrides can cause that error.
and with the link @Curtis_W gave about the XML tags,
it reminded me that certain characters/symbols need their styleoverrides. and removing the styleoverride will cause an issue
the symbols are mostly these ones.
as for the updated code. it will look like this:
'Logger.Info("Method3")
'Logger.Info(eText)
'Change All the styleoverrides, add Styleovverride when there is none applied
Dim sNewStyle As String = "Font='Tahoma' FontSize='0.3' Bold='False' Underline='False'"
Dim sNewStyleSymbols As String = "Font='AIGDT' FontSize='0.3' Bold='False' Underline='False'" 'this is used for the 'special' drafting symbols that needs the AIGDT font to work
Dim eTextNew As String = String.Empty
	'Logger.Info(subText)
	If Not subText.Contains("'>") Then
		'This infers that no style override is found, so apply the styleoverride
		subText = "<StyleOverride " & sNewStyle & ">" & subText & "</StyleOverride>"
	Else
		'With Styleoverrides
		If sOldStyle.Contains("Font='AIGDT'") Then
			subText = "<StyleOverride " & subText.Replace(sOldStyle, sNewStyleSymbols)
		Else
			subText = "<StyleOverride " & subText.Replace(sOldStyle, sNewStyle)
		'Now we need to check if the subText has some portion w/o any styleoverrides
		Dim sText2 As String() = subText.Split("</StyleOverride>")
		sText2(0) = sText2(0) & "</StyleOverride>" 'this is the portion where the current styleoverride applies
		If sText2.Length > 1 Then 'this is just to prevent some error (as i'm not 100% sure the Split will always return 2 items as 2nd item, sText2(1), might be an empty string).
			sText2(1) = "<StyleOverride " & sNewStyle & ">" & sText2(1) & "</StyleOverride>" 'this portion is something the styleoverride isn't applied yet so add the styleoverride
			subText = sText2(0) & sText2(1)
		Else
			subText = sText2(0)
	eTextNew &= subText
Next
oPickedDrawingNote.FormattedText = eTextNew
