iLogic Code for single sheet pdf creation
Message 1 of 9
Hi all, I am new to iLogic having an issue getting my pdf creator to work. So far I have two, one that creates all drawing sheets in one pdf. This works great.
The other single drawing pdf creator works, but doesn't keep the correct part number.
Say I have an assembly drawing, A570abcd, and 11 more sheet drawings that are the parts, A510EFGH, A510IJKL etc. that make up the the entire assembly.
What I want to do with my code is create only A510EFGH and have the pdf named correctly. Currently it only names it A570abcd.
I want to know how to get my code to read the part number of the model on the active sheet.
Below is one of the many code iterations I've tried:
 '------start of iLogic-------
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentsheet
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = opath
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
 I know the line - oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf" - is the issue. I just can't figure out how to read the iProperties part number of the part on the drawing.
Van
Replies (8)
Message 2 of 9
skyngu
modify the line:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1099 StartFragment: 314 EndFragment: 1067 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
oFileName=iProperties.Value("Project", "Part Number")
the code you provided works fine on my company inventor 2014 sp2
Autodesk Inventor Professional 2019
Message 3 of 9
GosponZ
Try this
'Set PDF target folder path
oFolder = "C:\
oDataMedium.FileName = oFolder&"\"&oFileName&" "&sSheetName&" "&sSheetNumber&".pdf"
Message 4 of 9
GosponZ
Ok here is complete code and save separate pdf's.
For your need add or remove part of code what is after part number.
Also change path.
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Define the drawing
DimoDrawingAsDrawingDocument
oDrawing = ThisDoc.Document
DimoSheetAsSheet
DimlPosAsLong
DimrPosAsLong
DimsLenAsLong
DimsSheetNameAsString
DimsSheetNumberAsInteger
'step through each drawing sheet
ForEachoSheetInoDrawing.Sheets
'find the seperator in the sheet name:number
lPos = InStr(oSheet.Name, ":")
'find the number of characters in the sheet name
sLen = Len(oSheet.Name)
'find the sheet name
sSheetName = Left(oSheet.Name, lPos-1)
'find the sheet number
sSheetNumber = Right(oSheet.Name, sLen-lPos)
'set PDF Options
IfoPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions)Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = sSheetNumber
oOptions.Value("Custom_End_Sheet") = sSheetNumber
EndIf
'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
oFolder = "C:\"
IfNotSystem.IO.Directory.Exists(oFolder)Then
EndIf
'Publish document
Next
Message 5 of 9
While this works well & creates all of the pdfs, it doesn't only create the active sheet I'm looking at.
Also, for the target name I'm looking for something like this;
oDataMedium.FileName = oFolder & "\" & sSheetName & ".pdf"
But "SheetName" isn't autofed from the iproperties of the part.
The attached picture of my drawing tree shows the breakdown of part drawings on sheets.
A57xxxxx is my top level assembly
--A51xxxxx are the parts making that assembly
The issue is the iProperties of this drawing file are only fed from the  A57xxxxx model and not the individual piece parts.
Message 6 of 9
Would I be able to drive my sheet names from the parts I place on each drawing? If there is a way to make a form for that, I believe that'd be the a really good route to take.
Message 7 of 9
GosponZ
Trigger this rule before save doc
You can remove Authority value if you do not need. or add what you want .Your browser tree will have this values and after you run pdf rule every sheet got own number  and description
oDoc=ThisDoc.Document
oSheets=oDoc.Sheets
ForEachoSheetInoSheets
oSheet.activate
oView=oSheet.DrawingViews.Item(1)
modelName=oView.ReferencedDocumentDescriptor.ReferencedDocument
oProp=modelName.PropertySets.Item("Design Tracking Properties")
ActiveSheet.Sheet.Name=oProp.Item("Part Number").Value&""&oProp.Item("Description").Value&""&oProp.Item("Authority").Value
Next
oSheets(1).activate
Message 8 of 9
oSheets=oDoc.Sheets
oSheet.activate
Next
oSheets(1).activate
This is exactly what i was looking for! Thanks MisterZS.
Message 9 of 9
GosponZ
I'm glad if i can share. Smiley Wink
