iLogic code for Drawing View Label
evettem
evettem
Can you please assist me with the correct settings (iLogic?).
In the View Label: (for new drawing views)
I've managed to change the text format to GENISO but for some reason the line spacing won't change as well.
(at the moment we have to change it manually after the view is placed but it is very time consuming)
It should be changed to the "exact" line space setting.
and also
can you please give me an iLogic code for the line space setting in existing drawing view labels?
as mentioned above "exact" line space.
Thank you in advance,
Evette
salariua
I have a possible solution for you.
You can actually see what the current format of the view label is and you can use this formatting when customizing the view label with ilogic.
follow this link to find how to see the format of view label.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
