iLogic Code Error: (Exception from HRESULT: 0x80004005 (E_FAIL))
I have some code that calculates cross-sectional area and area moments of inertia for a part file. Now I am trying to use the same code in an assembly file, and I am getting the following error:
     Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
From what I've read on the forums, it seems there can be several different issues that cause this. What can I do to fix my code?
I attached the assembly file which contains the iLogic code, as well as the part files that I was using with the code.  (I have commented out some of my code, so I can focus on getting the basics first).
Thanks.
JamieVJohnson2
Assemblies don't have material:
            iProperties.Value("Custom", "Material") = Format(iProperties.Material)
            iProperties.Value("Custom", "Drawn By") = Format(UCase(iProperties.Value("Summary", "Author")))
Their components do, but you are not cycling through components here.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
