iLogic Check End of Part
eugenio_fU5HMF
eugenio_fU5HMF
Goodmorning Folks,
I was looking for an Ilogic that give me back an error message if the "end fo part" of an .ipt is not at the bottom of the three.
This can avoid us to forget to move down the "end of part" and be sure the part is complete with all features.
Thanks for your help.
Ciao
Gabriel_Watson
Use the "HealthStatusEnum.kBeyondStopNodeHealth":
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-58D84911-253B-47F3-ABE7-3BF323CA85AD
For example:
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim FeatureList As New ArrayList
For Each oFeature In openDoc.ComponentDefinition.Features
    If oFeature.HealthStatus = HealthStatusEnum.kBeyondStopNodeHealth = True  Then
            FeatureList.Add(oFeature.Name)
Next
' Count the number of items in the FeatureList array
Dim FeatureCount As Integer
FeatureCount = FeatureList.Count
'Message box (customize this as you wish):
MessageBox.Show(FeatureCount, "Warning, features found below the End of Part marker:")
eugenio_fU5HMF
Thanks so much for your solution.
Is it possible to edit this script and receive back the message just if the end of part is up?
Gabriel_Watson
Sure, you can modify the prompt any way you like. Add a condition:
If FeatureCount <> 0  Then
        MessageBox.Show(FeatureCount, "Number of features below End of Part:")
eugenio_fU5HMF
Thanks so much.
