iLogic Changing View Scale
Hello, I have a code snippet here, and i was wondering if i can use this to only change one certian view scale and not mess with the other scales?
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 6555 StartFragment: 314 EndFragment: 6523 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet
Dim oSheets As Sheets
Dim oView As DrawingView
Dim oViews As DrawingViews
Dim oScale As Double
oSheets = oDrawDoc.Sheets
For Each oSheet In oSheets
   oViews = oSheet.DrawingViews
   For Each oView In oViews
oScale = InputBox("Enter Desired Scale", "Scaler", "1")
       If oView.ScaleFromBase = False Then
           oView.Scale = oScale
   Next
Next
You can, however, if the number of views will always change, then you will have to be a little more creative and create a counter or something.
You need to know how to interrogate the model which you can find at the blog modthemachine.
The code that follows allows you to interrogate the object follows.
dim whatever document you are using, drawing, part, or assembly.
Sub Main()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
End Sub
This code will get the one view changed as I think you are requesting.
oViews = oSheet.DrawingViews.item(whatever number view you want to change).scale = (your input)
When you find out what the item number is, then you can change only that one view.
Good Luck
Owner2229
Hi, pasting here from the msg I send you, as others might use it as well:
For Each oSheet As Sheet In oDrawDoc.Sheets
    For Each oView In oSheet.DrawingViews
        If oView.ScaleFromBase Then Continue For
        If oView.Camera.ViewOrientationType.ToString = "kIsoTopRightViewOrientation" Then
    Next
Next
The names of the ISO views:
kIsoBottomLeftViewOrientation
kIsoBottomRightViewOrientation
kIsoTopLeftViewOrientation
If you want it to work for "all" these ISO views, you can replace the red line with this:
If Left(oView.Camera.ViewOrientationType.ToString, 4) = "kIso" Then
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
k14348
  i want to check what are all the scales used in Active sheet.idw? In our company we have to use limited scales. But if someone made non standard scale view i have to find that. So Can i get vba code for that?
2nd requirement:-
            I want to limit the scale for the views. Example  everyone should use 1:1, 1/5,1/10,1/20,1/50 we should have to use only the mentioned scale. We should not allow others to use different scales. Any idea?
Thank you,
karthikeyanM
P_Korgaonkar
Hello All,
The code is working fine, and it changes each view to the desired scale.
It keeps asking scale for each view.
What I am trying to do is a little different.
I am creating Flatt Pattern drawing for Laser cutting, and all the views must be of the same scale.
I need each and every view on the sheet to be same. So I prefer to set scale only once and all the views should change to that scale.
to avoid confusion I have copy-paste the code given by Emiller29 at the start of this thread.
Any help appreciated
Regards
Parag
Dim oSheet As Sheet
   Next
Nexto
