iLogic changes all features' color, but failed for some features
jingying_1213
jingying_1213
I have some parts and I need to only change the color for all the features rather than changing the material. I write below codes which works well for a part, however it doesnot work well for a sheet metal part.
Please see below screen shot, when I run the codes for the sheet metal part, it does change the color to orange but it misses two areas on the flange features.
Can someone help and advise where is my problem?
Thanks!
Sub Main()
	Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oColorList As New ArrayList
	oColorList.Add("BZ - Blue Zinc Plating")
	oColorList.Add("Natural Yellow (Ko)")
	oColorList.Add("Orange (Joy)")
	oColorList.Add("Tech Pubs - 1st Alternative")
	Dim oSelectedColor As String
	oSelectedColor = InputListBox("Choose one color.", oColorList, "BZ - Blue Zinc Plating", "Color List", "List")
	Dim oLocalAsset As Asset
	Try
		oLocalAsset = oPDoc.Assets.Item(oSelectedColor)
	Catch
		Dim oAppLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Ko_Matl_App")
		Dim oLibAsset As Asset = oAppLib.AppearanceAssets.Item(oSelectedColor)
		oLocalAsset = oLibAsset.CopyTo(oPDoc)
	End Try
	Dim oPCompDef As PartComponentDefinition = oPDoc.ComponentDefinition
	Dim oPFeatures As PartFeatures = oPCompDef.Features
	Dim oPFeature As PartFeature
	For Each oPFeature In oPFeatures
		oPFeature.Appearance = oLocalAsset
	Next
End Sub
Dev_rim
Maybe this article can help you. I hope it will solve your problem.
https://modthemachine.typepad.com/my_weblog/2009/02/controlling-part-colors.html
Also if you can upload the ipt it can be more helpful for me.
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
jingying_1213
I think I have figure out this issue. Because there is a bend feature associated with the flange feature. However, although the above codes have changed the color of the flange feature but the associated bend feature's color is not changed. So I modify my codes as below, that works well now. Share with you.
Sub Main()
	'Set color list.
	'Select a color you want from the color list.
	'See if the selected color exists already.
	Try
	Catch
	End Try
	Dim oPCompDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
	Dim oPFeatures As SheetMetalFeatures = oPCompDef.Features
		Select Case oPFeature.Type
			Case 151001344	'Identify this is flange feature.
				Dim oName As String = oPFeature.Name
				MessageBox.Show(oName, "oPFeature.Name")
				Dim oFlangeFeature As FlangeFeature = oPFeatures.FlangeFeatures.Item(oName)
				Dim oBendFeature As BendFeature = oFlangeFeature.BendFeature
				oBendFeature.Appearance = oLocalAsset
			Case Else
		End Select
	Next
End Sub
