ilogic change source of linked ipt
Darrell.johnson
Darrell.johnson
Hi everybody,
i found this post:
https://forums.autodesk.com/t5/inventor-customization/ilogic-change-source-of-embeded-excel-sheet/m-...
Is it possible to change the source of linked inventor parts (.ipt) in a simialar way?
machiel.veldkamp
Do you mean derived components?
Try this:
Dim oDoc as Document
oDoc = ThisDoc.Document
Dim oRefFile As FileDescriptor
Dim oOrigRefName As Object
Dim selectedfile As String
For Each oRefFile In oDoc.File.ReferencedFileDescriptors
	'get the full file path to the original internal ref3erences
	oOrigRefName = oRefFile.FullFileName
	'present a File Selection dialog
	Dim oFileDlg As Inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(oFileDlg)
	oFileDlg.InitialDirectory = oOrigRefName
	oFileDlg.CancelError = True
	On Error Resume Next
	oFileDlg.ShowOpen()
	If Err.Number <> 0 Then
		MessageBox.Show("1", "Title")
		Return
	ElseIf oFileDlg.FileName <> "" Then
		selectedfile = oFileDlg.FileName
		MessageBox.Show(selectedfile, "Title")
	'replace the reference
	oRefFile.ReplaceReference(selectedfile)
	InventorVb.DocumentUpdate()
	oOrigRefName = ""
Next
iLogicVb.UpdateWhenDone = True
___________________________
Darrell.johnson
I want to change the marked path via iLogic.
Sergio.D.Suárez
Hi, is this what you need?
[video]
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
oFileDlg.DialogTitle = "Select a File"
oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.ShowOpen()
If oFileDlg.FileName = "" Then Exit Sub
 doc = ThisDoc.Document
 Dim oFD As FileDescriptor
 oFD = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
 oFD.ReplaceReference(selectedfile)
 doc.Update()
 I hope it helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Darrell.johnson
This is exactly what I needed. Thank you very much
