iLogic: Change of Document units (RAD -> DEG)
How can i make an External rule with the function of changing the Document Units, Angle from RADIAN to DEGREE?
The reason i want to make this rule is for i have to update files.
I'm new in iLogic and have a lot too learn. So hopefully does someone know the code i would have to use.
Thanks, Joop
JhoelForshav
Hi @Anonymous
You're talking about the document settings, right?
You can change it like this:
ThisApplication.ActiveDocument.UnitsOfMeasure.AngleUnits = UnitsTypeEnum.kDegreeAngleUnits
Hello Jhoel, thanks for the code. It was indeed Units form Document Settings. Now made an Xternal rule so i can use it always.
Greetings, Joop
ppolcynBNVFN
This was exactly what I was looking for. If you want to change to inches and pounds too you can use the following code:
ThisApplication.ActiveDocument.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kInchLengthUnits
ThisApplication.ActiveDocument.UnitsOfMeasure.MassUnits = UnitsTypeEnum.kLbMassMassUnits
