ilogic: Change component assembly material
dialunau
dialunau
Hello everyone, I'm using ilogic to create an assembly, but I need to change the material of the components. I'm trying to change it when defining the component's operations, but it just doesn't seem to work. I'm trying to use the method:
iProperties.Material = "Copper"
But it just won't work.
The following is a part of my code where I make a part and try to change its material before placing it in the assembly:
Public Sub Main()
'/ Assembly Definitions /
	Dim BaugDok As AssemblyDocument
	Dim BaugDef As AssemblyComponentDefinition
	Dim BautDok As PartDocument
	Dim BautDef As PartComponentDefinition
	Dim Martrix As Matrix
	Dim Occ As ComponentOccurrence
	check = False
	BaugDok = ThisApplication.ActiveDocument
	BaugDef = BaugDok.ComponentDefinition
'/ Call the function that creates the part /
    BautDok = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject,ThisApplication.FileManager.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject,SystemOfMeasureEnum.kDefaultSystemOfMeasure,DraftingStandardEnum.kDefault_DraftingStandard,"{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"))
    BautDef = BautDok.ComponentDefinition
	Call LBW()
'/ Give a 45 gegrees orientation /
	Martrix = ThisApplication.TransientGeometry.CreateMatrix()
    Martrix.SetToRotation(3.14159265358979 / 4, _
                            ThisApplication.TransientGeometry.CreateVector(0, 0, 0), ThisApplication.TransientGeometry.CreatePoint(0, 0, 0))
'/ Place component in origin /
    Martrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(0, 0, 0))
   	Occ = BaugDef.Occurrences.AddByComponentDefinition(BautDef, Martrix)
End Sub
'/ Functions to create part /
Sub LBW()
    Dim partDoc As PartDocument
    Dim iApp As Inventor.Application
    Dim partDef As PartComponentDefinition
    Dim sketch1 As Sketch
    Dim sk As Sketch
    Dim tg As Inventor.TransientGeometry
    Dim SWCurve As SketchArc
    partDoc = ThisApplication.ActiveDocument
    partDef = partDoc.ComponentDefinition
    iApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
    tg = iApp.TransientGeometry
    Call LBWPROF(sketch1, tg, partDef, sk)
End Sub
Public Function LBWPROF(sketch1, tg, partDef, sk) As Double
	Dim Path As Path
    Dim PF As Profile
    Dim SWP As SweepFeature
    sketch1 = partDef.Sketches.Add(partDef.WorkPlanes.Item(3))
    sketch1.SketchCircles.AddByCenterRadius(tg.CreatePoint2d(0, 0), 0.47625)
    sketch1.SketchCircles.AddByCenterRadius(tg.CreatePoint2d(0, 0), .42035)
    sk = partDef.Sketches.Add(partDef.WorkPlanes.Item(2))
    sk.SketchArcs.AddByCenterStartEndPoint(tg.CreatePoint2d(-2.54/2,0), tg.CreatePoint2d(0,0), tg.CreatePoint2d(-2.54,0),False)
    SWCurve = partDef.Sketches.Item(2).SketchArcs.Item(1)
    Path = partDef.Features.CreatePath(SWCurve)
    PF = partDef.Sketches.Item(1).Profiles.AddForSolid(True)
    SWP = partDef.Features.SweepFeatures.AddUsingPath(PF, Path, kJoinOperation)
End Function
Thanks in advance.
dialunau
This is an example of my project, I'm trying to change the material but nothing seems to work.
WCrihfield
I think it would be easier for you if you set up your "LBW" sub so it requests the input variables of the PartDocument and maybe even the PartComponentDefinition, so you don't have to redefine them within the sub.  I noticed that currently within that sub you are defining your variable "partDoc" equal to ThisApplication.ActiveDocument.  I think this is wrong, because the assembly is the active document.  You just created the part document just before you called that sub, and set it as the value of your "BautDok" variable, so it would make sense to supply that "BautDok" variable to the sub, instead of attempting to redefine it within the sub.
Also, since you are simply using all the default settings when creating the part document, you can greatly simplify that line of code from this
to this:
BautDok = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
 and it should still work OK.
Also, after you've defined the variable "oMaterial As Asset", I think you may need to change your line which sets its value from this:
oMaterial = partDoc.Materials.Item("Copper")
to this:
oMaterial = partDoc.MaterialAssets.Item("Copper")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
(Not an Autodesk Employee)
dialunau
Thanks a lot for your explanations, they really gave me a lot of help. However, I still couldn't change the material after those modifications to my code.
I found this thread, and they gave me exactly what I needed to change the material of my part:
https://forums.autodesk.com/t5/inventor-customization/ilogic-to-access-material-information/m-p/8633...
So I just added the following code right after calling my LBW Function:
'/ Change part material /
	Dim oPartMat As MaterialAsset
	Dim AssetLibs As AssetLibraries = ThisApplication.AssetLibraries
	Dim AssetLib As AssetLibrary
	For Each AssetLib In AssetLibs
		Dim oMaterialAssets As AssetsEnumerator = AssetLib.MaterialAssets
		Dim oMaterial As MaterialAsset
		For Each oMaterial In oMaterialAssets
			If oMaterial.DisplayName = "Steel, Galvanized" Then
				oPartMat = oMaterial
				Exit For
		Next
	Next
	BautDok.ActiveMaterial = oPartMat
