iLogic - Change appearance (get it from a Material Library)
mgFNR8M
mgFNR8M
Hi.
How can I change the current part appearance to an appearance saved on a library?
I tested this, but it only changes the appearance to the default one (grey).
ThisApplication.ActiveDocument.ActiveRenderStyle = ThisApplication.ActiveDocument.RenderStyles.Item("Appearance Name")
I don't know hot to get it from a library (not the current file).
Any help?
Thanks!
mgFNR8M
Done.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim Name As String = "Appearance Name"
Dim localAsset As Asset = Nothing
Try
	localAsset = oDoc.Assets.Item(Name)
Catch
	Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Library Name")
	Dim libAsset As Asset = assetLib.AppearanceAssets.Item(Name)
	localAsset = libAsset.CopyTo(oDoc)
End Try
oDoc.ActiveAppearance = localAsset
Call oDoc.BrowserPanes.ActivePane.TopNode.DoSelect
WCrihfield
Hi @mgFNR8M.  Besides the Inventor API way, like shown above, there is also this iLogic shortcut snippet you could try.  I just can not remember if it will copy in the appearance from the active library for you, if it is not found locally, or not.
iProperties.PartColor = "AppearanceName"
Here is the online documentation about it:
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=5cf3ba03-b3a3-d8ae-1923-4edd807fb7a6
Edit:  Here is also a link to the online help documentation about Materials & Appearances which tells you that the 'Material' object and the 'RenderStyle' related stuff was retired back in 2013, just for reference.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-2912C0FB-885F-47ED-81C3-AF19584EA9C1
Wesley Crihfield
(Not an Autodesk Employee)
mgFNR8M
That's perfect. That simple line does exactly what I need.
(it gets the appearance from the file and if it doesn't exists it copies from the active library)
Thanks!!!
