iLogic case sensitive
meck
meck
I'm reading data out of an Excel file using iLogic. I've noticed that while finding a row (GoExcel.FindRow) that the matching cell value has to have a matching case also. Is there a way to ignor the case and just match the text? I'm currently working around it by switching everything to upper case, but that is only so I can continue on. I really need to able to ignor the case.
Here's my code:
i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "="BrgManSeriesBore)
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
MjDeck
Here is some code to match different cases in the Excel data.  We should probably add an option to ignore case.
i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "=",  BrgManSeriesBore)
If (i < 0) Then
  i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "=",  [BrgManSeriesBore].ToUpper) ' match all uppercase
End if
If (i < 0) Then
  i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "=",  [BrgManSeriesBore].ToLower) ' match all lowercase
End if
If (i < 0) Then
  i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "=",  StrConv(BrgManSeriesBore, VbStrConv.ProperCase)) ' match with first letters capitalized
End if
There is another option that involves less code, but it requires that none of the cells in the column contains a string that is a substring of another cell.  You can use the "Contains" option to search instead of "=".  This will ignore the case.
i = GoExcel.FindRow(DBLocation & "Bases.xlsx", "RefSheet", "ManSeriesBore", "Contains",  BrgManSeriesBore)
Mike Deck
Software Developer
meck
Thanks!
Mike Eck
Using Inventor 2018
