Ilogic Case or If, ElseIf, Then.
jostroopers
Message 1 of 8
jostroopers
I want to make a rule when the parameter 'Diepte' has a value then some parts have to be suppressed.
I did that whit a Case but that dus not work.
The problem is the second case when a value is between to values it dus not change the suppressed state.
Select Case Diepte
Case <1050 mm
	Component.IsActive("10260:1") = True
	Component.IsActive("10260:2") = True
	Component.IsActive("10261:1") = False
	Component.IsActive("10262:1") = False
	Component.IsActive("10261:2") = False
	Component.IsActive("10262:2") = False
Case (Diepte>=1050)  And (Diepte<1550)
	Component.IsActive("10260:1") = False
	Component.IsActive("10260:2") = False
	Component.IsActive("10261:1") = True
	Component.IsActive("10261:2") = True
Case >=1550 mm
	Component.IsActive("10262:1") = True
	Component.IsActive("10262:2") = True
Now i did the same with a If, ElseIf, Then and then it works.
If Diepte <= 1050 Then
ElseIf Diepte > 1050 And Diepte <= 1550 Then
ElseIf Diepte > 1550 Then
 What is wrong with the case code?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Replies (7)
Message 2 of 8
Martin-Winkler-Consulting
@jostroopers
Try without the ( ) in
Case Diepte>=1050  And Diepte<1550
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Message 3 of 8
JhoelForshav
Hi @jostroopers
Dont use "And", just use a simple "," like this 🙂
Select Case Diepte
Case <1050 mm
Case >=1050, <1550
Case >=1550 mm
End Select
Message 4 of 8
jostroopers
Hi Martin
This does not bring the desired result
Mvg Jos
Message 5 of 8
jostroopers
Hi, JhoelForshav
If I start with a depth measure below 1050 it goes well. If I then go to a size between 1100 and 1500 it goes well too. If I now go to a size larger than 1550 then nothing will happen.
Select Case Diepte
Case <1050 mm
Case >=1050, <1550
Case >=1550 mm
End Select
Mvg Jos
Message 6 of 8
JhoelForshav
You're right... My bad.
The comma is interpreted more like "Or"...
This should work though:
Select Case True
Case Diepte < 1050
Case Diepte >= 1050 AndAlso Diepte < 1550
Case Diepte >= 1550
End Select
Or if you change the order a bit you can use "To":
Select Case Diepte
	Case < 1050
	Case >= 1550
	Case 1050 To 1550
End Select
Message 7 of 8
JhoelForshav
Because of the order though, this works too... Probably the best solution:
Select Case Diepte
	Case < 1050
	Case < 1550
	Case >= 1550
End Select
Message 8 of 8
jostroopers
Thanks JhoelForshav.
This sollution works.
Mvg Jos
