iLogic-Can't Copy and save an Assembly under the same name as a deleted Assembly
The title is a little complicated so let me try and simplify. I'm using iLogic to create a wall builder. Currently I am trying to copy an assembly of a door from another location to my wall file. It worked once, but I deleted the door file and tried to recreate it and it gives me this error
It works for a unique name but if I delete the door file from the wall file, I can't recopy the file under the same name.
Here's my code.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim Dcounter As Integer
Dcounter = 0
For Each oOcc In oDoc.ComponentDefinition.Occurrences
   If oOcc.Name.Contains("DOOR") Then
   Dcounter = Dcounter + 1
Next
Dim nextdoor As Integer
nextdoor = Dcounter + 1
Dim nextdoorname As String
nextdoorname = "DOOR" & nextdoor
Dim DocPath As String
DocPath = ThisDoc.Path & "\"
Dim DoorPath As String
DoorPath = "Z:\DRAWINGS\INVENTOR MODELS\2000-XXXXX (KITS, WEDLEMNTS)\29XX-XXXXX FR\DOOR\DOOR MAKER.iam"
Dim NewDoorPath As String
NewDoorPath = DocPath & nextdoorname & ".iam"
Dim oDoorDoc As AssemblyDocument
Try
	Try
		oDoorDoc = ThisApplication.Documents.Open(DoorPath, False)
	Catch
		MessageBox.Show("Could not find " & DoorPath)
	End Try
	Try
	oDoorDoc.SaveAs(NewDoorPath, True)
	oDoorDoc.Close
	Catch ex As Exception
		MessageBox.Show(ex.ToString())
		MessageBox.Show("COULD NOT COPY")
	End Try
	Catch
		MessageBox.Show("Failed")
End Try
HermJan.Otterman
I did see your error, but don't see exactly what you want to do. I don't see the deletion of a file.
I made the folling assumption:
- You have a Main Assembly (= oDoc),
- in this main assembly there is a door subassembly (= oOcc), with parts in it
(I got the error when this door sub assy was a part)
- DoorPath is the path to your Master door Assembly, that needs to be copied
so you open it in Inventor and save it to the location of the main assy and then close it..
you don't place it in your assy so the next time you run this the number (Dcounter) is still the same, even then I don't get the error any more.
So I checked my code again with yours and there are (almost) no differences
maybe an other way to copy a file without opening it in inventor:
Dim AssyInfo As New System.IO.FileInfo(Assyfullfilename) 'this would be the path to the "door_maker.iam"
Dim newAssyInfo As System.IO.FileInfo = AssyInfo.CopyTo(newAssyFullFilename, True) 'this would bet the new path
after this you need to place the file in the assy
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Cosmin_V
Are you using Vault?
I was placing the door in the assembly, but I left that part out as my code was failing at the copy and move stage. I deleted the file manually, not with ilogic.
Weirdly enough, I'm not having this issue or error anymore. I'm not aware of any changes other than the computer being restarted.
I will try your method of copying though.
Thank you, this is the only successful way I've been able to copy my sub assemblies.
WCrihfield
Have you considered using the built-in tool for this called "iLogic Design Copy"? Below are a couple of links to the online help pages that talk about it. https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-0BE1A21F-E2B4-4442-A4B9-F48C26210795 https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-ABFC1613-9A55-4772-B919-C530DC7D6973
Wesley Crihfield
(Not an Autodesk Employee)
This was an iLogic code problem. Copy design is great all in all. Just working with automated assemblies.
