Ilogic calculate length of 3D sketch
Hello!
I want Ilogic to calculate the length of a multiline in a 3D sketch. Is it possible?
Ralf_Krieg
Hello
Assuming:
- a part document is open
- the first 3D sketch contains the loop
- there's only this one loop in the sketch
you can do it with this little iLogic:
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As PartDocument = oApp.ActiveDocument
Dim oSketch As Sketch3D = oDoc.ComponentDefinition.Sketches3D.Item(1)
Dim oProfile3d As Profile3D = oSketch.Profiles3D.AddOpen
Dim dLoopLength As Double = oApp.MeasureTools.GetLoopLength(oProfile3d.Item(1))
oProfile3d.Delete
MsgBox ("Length of 3D loop: " & Round(dLoopLength, 2) & " cm")
R. Krieg
RKW Solutions
www.rkw-solutions.com
_dscholtes_
Please find below the steps I used to retrieve a set of connected lines / arcs / etc. from a sketch (to be used as a sweep path later).
1. find the start point in the sketch (by selecting it or assuming it's the first of all sketch points);
2. get the lines / arcs / etc. connected to it;
3. pick the one you didn't already process (otherwise it could go back and forth between two connected lines);
4. store the line / arc with the other already processed ones (collection);
5. get it's length and add it to the total length found so far;
6. get the other end point of the line / arc / etc.
7. use that point as the first point and continue from step 1 for each connected line / arc / etc.
The above is more a brute-force than an elegant / simple solution, but it's the only approach I could think of.
Manuelcamposcosta
thanks!!
I made a small change it was giving me an error on line 2 when saving trough an assembly.
Dim oDoc As PartDocument = ThisDoc.Document
Dim Comprimento As Double = oApp.MeasureTools.GetLoopLength(oProfile3d.Item(1)) * 10
oProfile3d.Delete
MsgBox ("Length of 3D loop: " & Round(dLoopLength, 2) & " mm")
Manuel Campos Costa
