iLogic - Batch insert Sheet Metal Thickness into Description
andrewdroth
Advisor Advisor
andrewdroth
I'm trying to make an iLogic rule that will sort through an assembly, and change the description of sheet metal parts to "=<Thickness> PL".
I found this thread that help for the sorting, and changing the custom parameter formatting, but I'm struggling making it work.
https://forums.autodesk.com/t5/inventor-customization/ilogic-batch-part-parameter-editor-rule-in-ass...
This is what I have, it seems to run through the parts, but it doesn't seem to make the changes I'm looking for.
SyntaxEditor Code Snippet
'Define the open document
Dim openDoc As Document
openDoc = ThisApplication.ActiveDocument
'Look at all of the files referenced in the open document
Dim partDoc As Document
For Each partDoc In openDoc.AllReferencedDocuments
     'look at only part files
     If partDoc.DocumentType = kPartDocumentObject Then
     'format file name
     Dim FNamePos As Long
     FNamePos = InStrRev(partDoc.FullFileName, "\", -1)
     Dim docFName As String
     docFName = Right(partDoc.FullFileName, Len(partDoc.FullFileName) - FNamePos)
          Dim userParam As UserParameter
          For Each userParam In partDoc.ComponentDefinition.Parameters.UserParameters
                If userParam.Name = "Thickness"
                      userParam.ExposedAsProperty = True
                     Dim cFormat As CustomPropertyFormat = userParam.CustomPropertyFormat
                     cFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType
                     cFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
                     cFormat.Units = "in"
                     iProperties.Value("Project", "Description")="=<Thickness> PL"
           Next
     'rebuild to update the display
     partDoc.Update
Next
openDoc.Rebuild
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
HermJan.Otterman
Hello Andrew,
I changed it a little in VB.net so so code is a little different, but it should work in iLogic
the Line:  cFormat.precision, did not work for my, so I left it out. you have to look in to that. (I'm working with metric files)
the main problem was that you where looking in the User prameters, and the Thickness is not a user parameter!
openDoc = Thisapplication.ActiveDocument
Dim oDoc As Inventor.Document
For Each oDoc In openDoc.AllReferencedDocuments
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = TryCast(oDoc, PartDocument)
Dim oCompdef As PartComponentDefinition = oPartDoc.ComponentDefinition
If oCompdef.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
'format file name
FNamePos = InStrRev(oPartDoc.FullFileName, "\", -1)
docFName = Strings.Right(oPartDoc.FullFileName, Len(oPartDoc.FullFileName) - FNamePos)
Dim oParam As Inventor.Parameter
For Each oParam In oPartDoc.ComponentDefinition.Parameters
If oParam.Name = "Thickness" Then
oParam.ExposedAsProperty = True
Dim cFormat As CustomPropertyFormat = oParam.CustomPropertyFormat
'cFormat.Precision = CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
Dim oDescription As Inventor.Property = oPartDoc.PropertySets("Design Tracking Properties").Item("Description")
oDescription.Value = "=<Thickness> PL"
'iProperties.Value("Project", "Description") = "=<Thickness> PL"
Next
oPartDoc.Update()
'End If
Next
openDoc.Rebuild()
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Owner2229
Just a little adjustment to Herm's code:
' Define the open document
Dim aDoc As Document = ThisApplication.ActiveDocument
If aDoc Is Nothing Then Exit Sub
' Look at all of the files referenced in the open document
For Each oDoc As Inventor.Document In aDoc.AllReferencedDocuments
	' Look at the sheet metal parts only
	If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
	Dim oCD As PartComponentDefinition = oDoc.ComponentDefinition
	' Format the file name. I don't realy see why would you need it here, so I'll comment it out
	'Dim FNP As Integer = InStrRev(oDoc.FullFileName, "\", -1)
	'Dim FName As String = Microsoft.VisualBasic.Mid(oDoc.FullFileName, FNamePos + 1)
	Dim oParam As Inventor.Parameter = oCD.Parameters.Item("Thickness")
	If oParam Is Nothing Then Continue For
	Dim oDescription As Inventor.Property = oDoc.PropertySets("Design Tracking Properties").Item("Description")
	' Update the document
	oDoc.Update()
Next
' Rebuild to update the display aDoc.Rebuild()
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
andrewdroth
Thanks guys!
That did it.
I just added the formatting for fractional units and it works perfect now.
	oDoc.Update()
Next
aDoc.Rebuild()
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
OK, so a change in plan.
The units need to be switched to metric.
The description format will be 'PL6' (=PL<Thickness>)
I've changed the
to
cFormat.Precision = CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
cFormat.Units = "mm"
But that doesn't seem to work. Any ideas?
This is the full code I'm trying.
     'format file name
		     cFormat.ShowUnitsString=False
		     iProperties.Value("Project", "Description")="=PL<Thickness>"
           Next
     partDoc.Update
Next
openDoc.Rebuild
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
Nevermind,
Somehow I edited the original non working code.
This works as it should now.
oDescription.Value = "=PL<Thickness>"
oDoc.Update()
Next
aDoc.Rebuild()
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
