ILogic automation of drawings
fons1
Message 1 of 1
fons1
Hello everyone,
I am starting using ILogic in our company and i would like to automate drawings of sheet metals.
When i create a sheet metal i would like an ilogic that would create a flat pattern, then open a custom template and create two sheets. On the first sheet there should be 4 views. 3 in each plane (top, right, front) and 1 flat pattern. On the second sheet there should be only Flat Pattern in scale 1:1. I would also like to have this view in center of my template and to change size of a sheet based on MAX dimension (length, width).  I found some I logic codes that i used and it finished some of my request. It created flat pattern, found and create a template with two sheets. It also placed some views but i cannot automate change size based on max dimensions, could somebody help me with that?
PS: Sorry for my bad English.
Here is a some mash up codes that i am using:
Dim oDrawingDoc As DrawingDocument
Dim oPartDoc As Document
Dim oSheet As Sheet
Dim oView1 As DrawingView
Dim oView2 As DrawingView
Dim oView3 As DrawingView
Dim oView4 As DrawingView
Dim oDoc As Document
Dim oFormat As SheetFormat
Dim oTG As TransientGeometry
Dim oViewScale As Double
Dim oViewScaleString As String
ViewScale = 1
'Ask to create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
    oPartDoc = ThisDoc.Document
    'Check to see if part is a sheetmetal part
    If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        'do nothing
    Else
        'ensure this part has a flat pattern
        Dim oSMDef As SheetMetalComponentDefinition
        oSMDef = oPartDoc.ComponentDefinition
        If oSMDef.FlatPattern Is Nothing Then
        'create flat pattern
        oSMDef.Unfold
        oSMDef.FlatPattern.ExitEdit
        Else
        'do nothing
'custom parametre pre sheet metal
openDoc = ThisDoc.Document
If openDoc.DocumentType = 12291 Then
    For Each oDoc In openDoc.AllReferencedDocuments
        'Is a Sheet Metal File
        If oDoc.SubType.Equals("{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
            'Obtain max & min flat sizes of part
            Dim smComp As SheetMetalComponentDefinition = oDoc.ComponentDefinition
            If smComp.HasFlatPattern Then
                'Get Units of Measure Object
                Dim uom As UnitsOfMeasure = oDoc.UnitsOfMeasure
                'Get FlatPattern Dims returned as the document units
                Length = uom.ConvertUnits(smComp.FlatPattern.Length, "cm", uom.LengthUnits)
                Width = uom.ConvertUnits(smComp.FlatPattern.Width, "cm", uom.LengthUnits)
                Flt_Ptrn_Len = Round(Length,0)
                Flt_Ptrn_Wid = Round(Width,0)
                Dim propertyName As String = "Blank Size"
                Dim propertyValue As String = Flt_Ptrn_Len & " x " & Flt_Ptrn_Wid
                customPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
      Try
         prop = customPropertySet.Item(propertyName)
      Catch
         ' Assume error means not found
         customPropertySet.Add("", propertyName)
      End Try
      prop.Value = Flt_Ptrn_Len &" x "& Flt_Ptrn_Wid
    Next
Else
'koniec mapovania nových premenných ////stránka s kódom: https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/flat-pattern-size-custom-iproperty/td-p/7304247
    'Define IDW Template File Location
    'oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Temp\my template.idw", True)
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2022\Templates\MKTECH\Výpalok.dwg", True)
   oSheet = oDrawingDoc.Sheets.Item(1)
      ' Create a new NameValueMap object
  Dim oBaseViewOptions As NameValueMap
  oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
 'True = folded view
 'False = flat pattern view
  oBaseViewOptions.Add("SheetMetalFoldedModel", False)
'Define 2d view bottom left corner points for four views
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(7.5, 10) ' front view
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(7.5, 15) ' top view
oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(15, 10)' right view
oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(14, 25)' flat pattern
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "My View")
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, ViewScale)
oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, ViewScale)
oView4 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint4, ViewScale,kDefaultViewOrientation, kHiddenLineDrawingViewStyle,,, oBaseViewOptions)
oSheet = oDrawingDoc.Sheets.Item(2) 'oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(10, 15)' flat pattern 'oView4 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint4, ViewScale, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oBaseViewOptions) End If
Replies (0)
