iLogic Auto Sort on Update check box - 2023
massimo.bertoAD8UX
massimo.bertoAD8UX
Hi All,
I am using Inventor 2023, and just messing around with some basic iLogic Rules (quite new stuff for me)...
I found in old threads some example for a BOM sorting by columns and add the "Auto Sort on Update" check box enabled.
the following code is sorting correctly the BOM in the drawing, but is not checking out the "Auto Sort" check box, am I missing something?
TIA
On Error Resume Next
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort2("ITEM", 1, AutoSortOnUpdate, True)
oPartsList1.Renumber
oPartsList1.SaveItemOverridesToBOM
massimo.bertoAD8UX
Ok, solved the problem :
must be :
oPartsList1.Sort2("ITEM", 1, AutoSortOnUpdate :=True)
Anyway, thanks!
