ilogic- assembly rule - part numbers update after design copy.
Hello
I have a little problem when I copy
I can't use the RULES because all the part numbers are changed
  is there a solution to change the part numbers in the rules or a code to use the rule for all the part numbers?
thank you
Curtis_Waguespack
Hi @Anonymous
See if this post from yesterday on the Inventor Customization forum answers your question:
https://forums.autodesk.com/t5/inventor-customization/automatically-update-assembly-parameter-from-part-component/m-p/9338660#M106225
Just a reminder, programming questions of this type are generally placed on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll as the forum moderators to move this thread to that forum for you.
I hope this helps.
Curtis
gcoombridge
Do your rules iterate through your part numbers or are you talking about occurrence names in the browser?
If it is the second refer to this blog. These need to be changed manually or with the ilohgic code on the log, then they will remain constant...https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020161-Inventor-2014-iLogic-Stabilise-Browse...
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
