iLogic assembly placement, not saving the parts
adam.robsonS72GJ
Message 1 of 1
adam.robsonS72GJ
Community Visitor
Community Visitor
Hi
I've got a problem with a particular iLogic assembly that I can't insert into an assembly. Whenever I try, I get a message saying that it's unable to open the file in the target assembly because it is not checked out to me
I click OK, and I get another message saying that it needs data from document that is a part within the assembly. When I click cancel, Inventor crashes.
The 'master' iLogic assembly in my library folder works fine, as in I can open it, use the form to run rules etc.
I can place an instance of the iLogic assembly in my library project OK
I can place other ilogic assemblies in my target assembly OK
I have made sure library paths are OK
I have tried Save As, different file name, of the 'master' ilogic assembly with the same result
Normally when I insert a Ilogic assy in a target, it saves all the part files but this one isn't
Any ideas what I'm doing wrong?
Thank you
Replies (0)
