iLogic Assembly has double user request at inserting in assembly
Hi all,
Here's the situation:
We have an iLogic assembly with to parts in it. Maybe to cylindrical parts. The iLogic rules should do the following.
1. Start a Rule after open document.
2. This Rule starts a Rule in the first cylindrical component.
3. This Rule ask the user for a diameter.
4. The assembly gives this new parameter value to the second component
5. Then the assembly calls another rule in the second component to change it with the new parameter
Everything is working fine when the following combinations are taking place:
1. I open up the assembly out of vault or from a local drive or an accessible server drive
2. I insert the assembly as sub assembly in another assembly from a local drive or an accessible server drive
It don't work with the following situation:
- I insert the assembly as sub assembly in another assembly out of vault
Then the user becomes the dialog "Choose a diameter" twice.
I don't know why, but I have the idea it has something to do with the functionality of inventor to insert a component more than once. If you insert a component in an assembly Inventor gives you the opportunity to add more than one occurence after each other.
So, any ideas to change that behaviour? Maybe a switch to change that inventor "add more than one occurence" behaviour. Maybe that's the solution?!
Best Regards
Passi
xiaodong_liang
Autodesk Support
Autodesk Support
Frankly, I am not clear what the scenarios are. I am not sure if other peers are clear, but can I suggest you provide a short video on the workflows described and share a small script of iLogic. They will be helpful for diagnosis, I think.
