[iLogic] Assembly/drawing parameter linking or going through browser
217694G9MEZ
217694G9MEZ
Hello, I have a rule that automaticly generates a drawing. Now i need to put dimensions there. This drawing is based on a assembly, that can change. I have 4 options that can change there and for each is a diferent set of dimensions. This options are based on one parameter and this parameter is selecting one option and suppressing the other three, that are not needed.
My question is how do i change the dimensions in drawing based on parameter that is selected in assembly? I thought of 2 options, but i cant get either of them working. First is somehow linking this parameter with the drawing (the drawing would know if its option 1,2,3,4 and would select the right dimensions) or secondly going through the browser, seeing what of these 4 options is not suppressed and selecting the right dimensions (picture i put here).
Thanks in advance and have a great day. 🙂
A.Acheson
Is it possible to provide a sample drawing or images of the workflow you want to automate? Dimension automation is a difficult subject as the learning curve is steep. You may need to start by assigning named faces to parts and trying to reference these faces. Here is a sample of adding a dimension to a drawing curve. And here is a post of named face with dimensions. It will give you a small idea of what might be involved
Regards
Alan
