iLogic Apperance
iLogic Apperance
Lukasz.Dudkowski
iLogic Apperance
Lukasz.Dudkowski
Could you please help me to create line of iLogic code with set default Appearance library ?
BR,
Łukasz Dudkowski
blandb
What exactly are you trying to do?
Autodesk Certified Professional
Lukasz.Dudkowski
I have a Global form from where I can change surface color. Everything is working ok to moment when I want to use that forms with old templates.
I see that when I set-up one of my Appearance style as default my rule is working properly with old files as well.
That's why I need code with set-up as a default one of defined appearance library. This will solve my issue.
My code is like this and picture of the form you can find below:
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Try
If Parameter("Customized_Color") = False
		oDoc.AppearanceSourceType = AppearanceSourceTypeEnum.kMaterialAppearance
	Else If Parameter("Customized_Color") = True
		iProperties.PartColor = Parameter("Surface_Color")
Catch
	MessageBox.Show("Surface color not changed !!! Change default appearance library to RAL_Appearance and update document", "Apperiance rule ERROR")
End Try
dutt.thakar
@Lukasz.Dudkowski
Are you looking for something like this? Add this in your catch block, and it will change the appearance library to "RAL_Appearance"
Dim oLib As AssetLibrary = ThisApplication.AssetLibraries.Item("RAL_Appearance")
ThisApplication.ActiveAppearanceLibrary = oLib
 If this is not what you are looking for please, try to explain in detail what you are trying to achieve.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Lukasz.Dudkowski
Thank you. Works like intended 🙂
