iLogic angle
iLogic angle
GeorgK
Advisor Advisor
iLogic angle
GeorgK
Hello Together,
how could I get the positive or negative angle?
angle = Measure.Angle("KR10_R1100_CR_6:2", "Arbeitsebene1", "KR6_R700_CR_5:1", "Arbeitsebene1")
MsgBox(angle,MessageBoxIcon.Exclamation)
Thank you Georg
Balaji_Ram
Hi Georg,
I do not see a way to let Measure.Angle to provide that information.
But, it should be possible to know on how the moving workplane is tilted by analyzing its normal vector.
Here are two screenshots to demonstrate this :
The iLogic code to retrieve the normal would be :
Dim oAssemblyDef As AssemblyComponentDefinition
oAssemblyDef = oPartDoc.ComponentDefinition
Dim oMovingPlane As WorkPlane
oMovingPlane = oAssemblyDef.WorkPlanes(5)
Dim movingPlane As Plane
movingPlane = oMovingPlane.Plane
Dim movingPlaneNormal As UnitVector
movingPlaneNormal = movingPlane.Normal
MessageBox.Show( "Moving X :" & movingPlaneNormal.X & " Y :" & movingPlaneNormal.Y & " Z :" & movingPlaneNormal.Z, "iLogic")
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
GeorgK
Hello Balaji,
the sample does not work. Thanks
Georg
Balaji_Ram
Hi Georg,
I will need more information / sample files to investigate this further and know what does not work.
In a sample assembly that i created that mimics the robot manipulator kind of assembly that you showed, the iLogic code did work.
Balaji
Balaji
Balaji_Ram
Hi Georg,
Thanks for sending me your sample files to understand the issue.
I have attached the sample files that I was in my tests earlier and a recording of the results to the discussion forum post.
http://autode.sk/1HfGIx5
I do not think, there is a direct way to let Measure.Angle return the angle value based on a reference.
It has no idea that the angle values are to be measured along a certain direction on the other work plane.
By identifying the normal of the moving plane, it is possible to get this information.
The iLogic code in the sample file is not a generic way, but will need to be tweaked to get it working depending on
which axis the two workplanes are constrained to rotate.
Hope this helps.
Balaji
Balaji
