Ilogic and grabbing model value into drawing
sreed
sreed
I have some rules setup to grab the Design State of a model to show up on a form in the IDW.  I have attached a drawing and the rules for you to look at.  What I would like to do now is grab the checked by and checked date of the model and have it show up in the .idw and be able to push it back to the model once it gets changed.  I don't know much about rules but am scheduled to get training.  Any help  is very appreciated.
clutsa
I added the code at the bottom. I commented out the code to push the data to the model (just remove the single quotes and paste it in the other rule.)
Try
    'check For Parameter
    oTest = Parameter("ModelDesignState")
Catch
    'create multi-value Text Parameter
    ThisDoc.Document.Parameters.UserParameters.AddByValue _
    ("ModelDesignState", "WorkInProgress", UnitsTypeEnum.kTextUnits)
End Try
'set list
MultiValue.SetList("ModelDesignState", "WorkInProgress", "Pending", "Released")
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheet = ActiveSheet.Sheet
oViews = oSheet.DrawingViews
If oViews.Count > 0 Then
	oView = oViews.Item(1)
	oModelName = oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	Dim referDoc As Document
	referDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	oAssemblyState = referDoc.PropertySets.Item("Design Tracking Properties").Item("Design Status").Value
	If oAssemblyState = 1 Then
		oAssemblyState = "WorkInProgress"
		Else If oAssemblyState = 2 Then
		oAssemblyState = "Pending"
		Else If oAssemblyState = 3 Then
		oAssemblyState = "Released"
	'MessageBox.Show(oAssemblyState, "Assembly State")
	Parameter("ModelDesignState") = oAssemblyState
	'push assy/part to drawing
	iProperties.Value("Design Tracking Properties", "Checked By") = referDoc.PropertySets.Item("Design Tracking Properties").Item("Checked By").Value
	iProperties.Value("Design Tracking Properties", "Date Checked") = referDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked").Value
'	'push drawing to assy/part
'	referDoc.PropertySets.Item("Design Tracking Properties").Item("Checked By").Value = iProperties.Value("Design Tracking Properties", "Checked By")
'	referDoc.PropertySets.Item("Design Tracking Properties").Item("Date Checked").Value = iProperties.Value("Design Tracking Properties", "Date Checked")
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
sreed
I pasted those line at the bottom of my rule and I get a bunch of errors.  See attached .jpg for errors.
clutsa
And you only need to copy those three lines to the new rule that will push data from the drawing to the model. (The first three go in the rule just as shown)
Quick lesson: in VB (visual basic) anything after a ' is ignored by the computer for the rest of that line unless the single quote is inside a double quote "'" (double single double)
