Ilogic and excell
Ilogic and excell
Message 1 of 16
Ilogic and excell
I created a parameter name called Material (multi line) and an excell file called Material as well. (A1=Nest-Pine A2=Nest-Oak A3=Nest-Maple). I need help on the ilogic end in order to have the parameter read the list in excell. I linked the excell file to my part file as well. Looking for help, thank you
Replies (15)
Message 2 of 16
MjDeck
Here's a rule statement that should do it:
MultiValue.List("Material") = GoExcel.CellValues("3rd Party:filename.xls", "Sheet1", "A1", "")
This will read down the column until it finds a blank cell.
If you want it to read only up to a particular cell (such as A3), use this instead:
MultiValue.List("Material") = GoExcel.CellValues("3rd Party:filename.xls", "Sheet1", "A1", "A3")
This is looking on Sheet1.  Change the filename and sheet name if necessary.
(In the iLogic rule editor, this is in the System Snippets under Excel Data Links -> MultiValue list from Excel).
Mike Deck
Software Developer
Autodesk, Inc.
Message 3 of 16
Thank you very much
Message 4 of 16
Would it be possible to have the parameter Material & Color read staight from my styles Material & Colors?
Message 5 of 16
MjDeck
This is not available for colors (but you could do it with the API).
For materials, here's a snippet:
MultiValue.List("Material") = iProperties.Materials
This is on the System Snippets, under iProperties -> List of Materials
It gives you all materials, so it's probably too much for any given part.
Mike Deck
Software Developer
Autodesk, Inc.
Message 6 of 16
Is it possible to pull the list of colors from the xml file? I tried this but it doesn't work
MultiValue.List("Color") = iLogicVb.Automation.ParametersXmlLoad(ThisDoc.Document, “G:\Design\Design Data\Colors.xml")
Message 7 of 16
In Ilogic under iproperties there is PartColor, is there a snippet that will allow me parameter field read the color iproperty. I tried the one below and received errors.
MultiValue.List("Color") = iProperties.PartColor
InventorVb.DocumentUpdate()
Message 8 of 16
MjDeck
This is pretty easy using the API.  Here's how to do it:
 Dim colors as New ArrayList
 For Each renderStyle As RenderStyle In ThisDoc.Document.RenderStyles
   colors.Add(renderStyle.Name)
 Next
 MultiValue.List("Color") = colors
Mike Deck
Software Developer
Autodesk, Inc.
Message 9 of 16
Ok, Thank you very much for your time
I am not familiar with API but I am ready and willing to learn.
Message 10 of 16
This looks like a great place to begin learning. Thought I would help others find the information as well. Good Luck to you all
http://modthemachine.typepad.com/my_weblog/begging-api/
http://www.caddigest.com/subjects/adsk_inventor/tutorials.htm
Autodesk Inventor API
Part 1-3
Message 11 of 16
Where do I input this code you provided?
Message 12 of 16
MjDeck
The code I provided:
 Next
can be used as an iLogic rule by itself.  Add a new rule in a part and paste in this code.
Mike Deck
Software Developer
Autodesk, Inc.
Message 13 of 16
NICE!
That worked like a charm, thank you very much for all your help.
Message 14 of 16
The parameter field filled in nicely, however when I pick a different color the part doesn't change with it. Would you know Why?
Message 15 of 16
MjDeck
You have to add another rule to hook up the Color parameter.  Add a rule with just this line:
iProperties.PartColor = Color
Mike Deck
Software Developer
Autodesk, Inc.
Message 16 of 16
Looks good, thanks again
I was receiving errors because I was entering all the codes under one rule.
