ilogic and custom iproperties
tuanvan3575
tuanvan3575
I have a rule to add a custom iPropteries "small" if either width or length of a part is > 1.5 and < 6.
iLogicVb.UpdateWhenDone = True
Dim pLength As Decimal = width
Dim pWidth As Decimal = length
'Dim pLength As Decimal = Measure.ExtentsLength'Dim pWidth As Decimal = Measure.ExtentsLength
'define custom property collection'oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")'look at each property in the collection'For Each oCustProp In oCustomPropertySet'check for a property name that you don't want to delete'If oCustProp.Name = "small" Then'delete the custom iProperty'oCustProp.Delete'Else'End If'Next
If pLength > 1.5 And  pLength < 6 Then
    iProperties.Value("Custom", "small") = "yes"
Else If pWidth > 1.5 And  pLength  < 6 Then
Else
    iProperties.Value("Custom", "small") = "no"
RuleParametersOutput()
InventorVb.DocumentUpdate()
 It doesn't work if I change the rule to
I have to run rule after change the parameter to have iProperties updated. Is there a way to update iProperties without run or regenerate the rule?
Tuan
rjay75
This is because while using the Measure options theres no parameters in the rule changing to automatically run the rule. Set an event trigger to run the rule before save.
Also since there are no parameters in the rule the document updating and outputting the parameters can be removed.
