iLogic advanced guide for common problems with Snippets
Here's a iLogic quick guide what will probably help people solve common questions asked about iLogic. Along with this file i've included a custom snippets file you can add to your own snippets.
In this documentation will contain a solution for the following:
1: Dividing lengths equal with a maximum length
2: Dividing length into standard parts with a variable length
3: Deleting Parts with certain names
4: Adding parts in a loop
5: Creating and Saving parts with unique part identities based on parameters
6: Main assembly replace unique parts with the created parts in 5
7: Call rules subassembly and parts stand alone
This is just a reaction to not confuse people, please leave your questions down below.
I decided to update the guide a little bit with adding some descriptions.
Also changed snippet 3 to detect any file containing whatever you want to detect in the name and return the occurance name as a string to use in the coding.
Here's the link to the new files:
https://forums.autodesk.com/t5/inventor-customization/ilogic-automate-assemblies-quick-guide-snippet...
