iLogic Add Thread Feature
ComputerGuru666
ComputerGuru666
Does anyone know if its possible to add a thread feature to a part using iLogic.
Basically in the iLogic form if the user selects "Threaded Rod" the existing Extrusion is updated to reflect a cylinder with a length and diameter specified by the user and then I need to have a Thread Added to the cylinder.
If that makes sense
Thank you
Computer Specs:
Windows 7 (64 Bit) Pro. SP1, Inventor 2014 Pro, 3D Connexion SpaceNavigator (Driver 3.15.2)
Motherboard: ASUS Rampage IV Extreme x79 Socket 2011
Processor: Intel Core i7 Six Core Sandy Bridge-E 3.2GHz OCed to 4.7GHz (Under Water)
RAM: G.Skill Ripjaw Z-Series 32 gig quad channel of RAM 1800MHz OCed to 2133MHz
Video Card: 2x Nvidia Geforce GTX 770 (Running Six (6) Monitors)
Monitors: [Primary = 2x 24in HD WS][Secondary = 2x 22in HD WS][Tertiary = 2x 19in FS]
Primary Hard Drive: OCZ Vertex IV 256 GB Solid State Drive
Secondary Hard Drive: OCZ Vertex III 120 GB Solid State Drive
Vladimir.Ananyev
Please try this sample iLogic rule.
It was developed on the basis of the VBA sample "ThreadSample" from Inventor API Help.
Dim oDef as partcomponentdefinition _
	= ThisDoc.Document.componentdefinition
'extrude feature by name (or by item number)
Dim oExtrude As extrudefeature _
	= odef.features.extrudefeatures.item("EXTR")
' Get the face the thread will be applied to.
Dim oFace As Face = oExtrude.SideFaces.Item(1)
' Get the edge the thread extent will be measured from.
Dim oEdge As Edge = oExtrude.EndFaces.Item(1).Edges.Item(1)
' Set a reference to the ThreadFeatures collection object.
Dim oThreadFeatures As ThreadFeatures = oDef.Features.ThreadFeatures
' Define all of the thread information.
Dim oThreadInfo As ThreadInfo
oThreadInfo = oThreadFeatures.CreateStandardThreadInfo( _
    False, True, "ANSI Unified Screw Threads", _
    "1 5/8-6 UN", "2A")
' Create the thread feature.
Dim oThreadFeature As ThreadFeature
oThreadFeature = oThreadFeatures.Add( _
	oFace, oEdge, oThreadInfo, _
    False, False, "2 cm", 0)
oThreadFeature.Name ="iLogic_Maiden_Thread"
Beep ' :)
Hope this can help you to modify your rule.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
