Ilogic - Add Standard Virtual Parts From an Excel File
brendan.henderson
Advisor Advisor
Message 1 of 25
brendan.henderson
I'm having a crack at using code supplied by @Curtis_Waguespack but it keeps producing an error, shown below.
I have changed the code to reflect the location and name of the excel file, and commented out some of the iProp rows I don't need.
Also attached is the excel file and the customised code. Really appreciate anybody having a look at this for me.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Accepted solutions (3)
Replies (24)
Message 21 of 25
Curtis_Waguespack
Hi @e_frissell ,
I think that would look like this. You might need to adjust a bit ( I didn't test) .
I hope this helps.
Curtis
Dim myXLS As String = "C:\TEMP\Test98.xlsx"
Dim oFileDlg As Inventor.FileDialog
Try
	GoExcel.Open(myXLS, "Sheet1")
Catch
	ThisApplication.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "Microsoft Excel Files (*.xlsx; *.xls)|*.xlsx;*.xls|"
	oFileDlg.ShowOpen()
	If oFileDlg.FileName = ""
		MessageBox.Show("Excel file not selected", "iLogic", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
		Exit Sub
	myXLS = oFileDlg.FileName
End Try
'do impressive things with the Excel data here
GoExcel.Close
Message 22 of 25
e_frissell
Way cool, that worked!  I had thought a return value would be needed if the file didn't exist to prevent an error but it works just fine
Message 23 of 25
Curtis_Waguespack
@e_frissell
This is another way to do this, that I think I like a better than the try/catch mostly because of the way the GoExcel function works behind the scenes. If you see any glitches with the try/catch version you might give this a try.
Dim oFilename As String = System.IO.Path.GetFileName(myXLS)
If System.IO.File.Exists(oFilename) = False Then
	oFileDlg.ShowOpen()
		Exit Sub
GoExcel.Close
Message 24 of 25
e_frissell
Nice!  The try-catch is working right now, and while I can't explain why I like this one more than the try catch method, I do like it and I'll update the code to this
Message 25 of 25
e_frissell
@Curtis_Waguespack funny story moved ahead with phase 2 of my script and the try-catch method posted the other day errored out, swapped it for this second method, and it works great
