ilogic add property from excel
tegstette
tegstette
HiSmiley Happy
I have a small problem... I have this ilogic rule that will add properties into my file from an Excel sheet.
First the user will enter the part number that gives the row where the information is to be found.
But what I do not get to work is: if the part number that the user enters do not exist in the Excel sheet, I want an Error message...
I have tried different things but dont get it to work...
Can someone please help?
' User will give part number in an input box:
strNum = InputBox("Please enter the part number", "Get Data")
' Excel sheet with information, column 1= Part Num, column 2=Description
i = GoExcel.FindRow("c:\export.xlsx", "Sheet1", "Part Num", "=", strNum)
'If strNum Is Not found Then
'MessageBox.Show("Part Number does not exist in Excel sheet", "Error")
'If i <> "Part Num"  Then
If strNum <> "" Then
Else
' Get property from excel
strDesc = GoExcel.CurrentRowValue("Description")
' Add properties
iProperties.Value("Project", "Part Number") = strNum
iProperties.Value("Project", "Description") = strDesc
Best regards
TG
Autodesk Inventor/Vault Professional 2021
Curtis_Waguespack
Hi tegstette,
In your example, i is returning the row number.
You can use this to see what row number is returned:
MessageBox.Show("Row Number is: " & i, "iLogic")
When the input is not found, the row number is returned as -1, so you can use something like this to catch the error:
i = GoExcel.FindRow("C:\TEMP\MyWorkBook.xlsx", "Sheet1", "Part Num", "=", strNum)
If i <= 0 Then
MessageBox.Show("Part Number Not Found", "Error")
I hope this helps.
Curtis
tegstette
Perfect!
Thank youSmiley Happy
Best regards
TG
