iLogic Add arc length under the existing angular dimension
infoEHE7X
infoEHE7X
I have written a code to get a value from the user and multiply half of it to the existing angular dimension in the sheet. The code has no error however, it doesn't work.
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim val As String = InputBox("Enter Shell OD in inch", "User Input")
If val = "" Or Not IsNumeric(val) Then
    MsgBox("Please enter a valid numeric value.")
    Exit Sub
Dim OD As Double = CDbl(val)
For Each oDim As GeneralDimension In oSheet.DrawingDimensions.GeneralDimensions
    If oDim.Type = DimensionTypeEnum.kAngularDimensionType Then
        ' Get the current angular dimension value
        Dim oAngleDim As AngularGeneralDimension = oDim
        Dim angleValue As Double = oAngleDim.ModelValue
        ' Multiply by the scale factor (user input value)
        Dim ARC As Double = angleValue * OD / 2
        ' Update the dimension text to show both original and new values
        oDim.Text.FormattedText = "<DimensionValue/><br/>" & ARC.ToString
Next
cidhelp
Hello @infoEHE7X ,
this seams like a bug in api. Using
117474816
instead of
 works for me.
cidhelp
no bug.
this is
kAngularGeneralDimensionObject
instead of
infoEHE7X
The correct code would be:
    Exit Sub
    If oDim.Type = ObjectTypeEnum.kAngularGeneralDimensionObject Then
Next
