IiLogic Select Case with greater than and less than combined
mark_h_ellis
mark_h_ellis
Hi Everyone
I'm trying to get a Select Case statement to run without producing unexpected results. I already have it to run with multiple IF THEN statements but thought I'd try to use a SELECT CASE statement.
Now as I see it the results are short circuiting so if it sees one side of the case as true it ignores the rest.
I have tried replacing '&' with AND and i end up with an error "Operator 'And' is not defined for types 'Autodesk.iLogic.Interfaces.DoubleForEquals' and 'Boolean'."
I also tried replacing the '&' for a comma to no avail.
CHUTE_TWIST_ANGLE & MITREANGLE1 & MITREANGLE2 are numeric degree parameters in the sketch.
Thought this would be an easy thing to achieve.
Here is the code.
Select CHUTE_TWIST_ANGLE
	Case Is <= MITREANGLE1
		Parameter("LCP_CHAMFER_A") = 10
		Parameter("LCP_CHAMFER_B") = 10
		Parameter("LCP_CLEAR_C") = 50
		Parameter("LCP_CLEAR_E") = 50
	Case Is > MITREANGLE1 & CHUTE_TWIST_ANGLE <= (90 - MITREANGLE2)
		Parameter("LCP_CLEAR_C") = Parameter("LCP_CLEAR_C") + 1000
		Parameter("LCP_CLEAR_C") = Parameter("LCP_CLEAR_C") - Parameter("LCP_CLEAR_D") + 50
	Case Is > (90 - MITREANGLE2)& CHUTE_TWIST_ANGLE <=90
		Parameter("LCP_CLEAR_E") = Parameter("LCP_CLEAR_E") + 1000
		Parameter("LCP_CLEAR_E") = Parameter("LCP_CLEAR_E") - Parameter("LCP_CLEAR_F") + 50
	Case Is >90
		MessageBox.Show("The maximum value for 'CHUTE TWIST ANGLE' is 90: " & vbCr & "The value will be automatically corrected.", "Maximum Value Rule", MessageBoxButtons.OK, MessageBoxIcon.Error)
		Parameter("CHUTE_TWIST_ANGLE") = 90
End Select
It will only ever run Case 1 & 2
nmunro
The & symbol is not valid in VB.Net and thus iLogic. You would need to use the AndAlso statement. Having said that your comparisons need not be so complicated. Here are If Then Else and Select Case examples that are a bit easier to follow and accomplish your goals.
If CHUTE_TWIST_ANGLE <= MITREANGLE1 Then
ElseIf CHUTE_TWIST_ANGLE <= (90 - MITREANGLE2) Then  'no need to check > MITTEANGLE1 as it must be to get this far
ElseIf CHUTE_TWIST_ANGLE <= 90 Then  'must already be > (90 - MITREANGLE2)
Else ' must be > 90
	Case Is <= (90 - MITREANGLE2)
	Case Is <=90
	Case Else
End Select
https://c3mcad.com
mark_h_ellis
Thankyou for that that makes easy and understandable sense for me.
