iFeature set plane rotation
ewu9
ewu9
Hi!
I'm convinced there's an easy to access/write this parameter when placing an iFeature, but I can't seem to figure out how to change the angle of the sketch plane in iLogic. Any pointers? I've been using the code for inserting a standard iFeature from the API reference manual.
My alternative solution is to build an angle parameter into the iFeature itself
    ' Set the input.
    Dim oInput As iFeatureInput
    For Each oInput In oiFeatureDef.iFeatureInputs
        Dim oParamInput As iFeatureParameterInput
        Select Case oInput.Name
            Case "Sketch Plane"
                Dim oPlaneInput As iFeatureSketchPlaneInput
                Set oPlaneInput = oInput
                oPlaneInput.PlaneInput = oFace
            Case "Diameter"
                Set oParamInput = oInput
                oParamInput.Expression = "1 in"
            Case "Depth"
                oParamInput.Expression = "0.5 in"
        End Select
    Next
    ' Create the iFeature.
    Dim oiFeature As iFeature
    Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
Michael.Navara
ewu9
Yes, that's exactly it. Thank you!
