iFeature Creation
iFeature Creation
cad_admin1
iFeature Creation
cad_admin1
Can anyone tell me if they've had any success in creating an ifeature from an extruded cut?  I keep on getting a placement error with mine which makes me think it might not be possible.  I've attached the ifeature .ide file and also the model i've extracted it from.  I've created other ifeatures with no problems at all but this is the first using an extruded cut.  We're currently still using 2016 version but will be upgrading to later this year.
YuhanZhang
Do you want to create a punch iFeature so you can use it to cut other solid? If yes you can refer to below video about how to create punch tool:
http://help.autodesk.com/view/INVNTOR/2017/ENU/?caas=caas/screencast/Main/Details/a4043913-7a77-4d82...
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
cad_admin1
Thanks for taking a look for me.  The punch tool is not available to me because this is not for sheet metal.  I have tried creating it using sheet metal but the punch hole feature only works if the sketch is drawn on a face and not using a workplane.  I need to be able to create the extruded cut with the fillets so placing the sketch on a face won't work (i don't think).
YuhanZhang
You do can create punch in standard part, if you in the Insert iFeatue dialog select a punch tool from the iFeature Catalog, you can see it also punches the solid. So if your purpose is to create an iFeature to cut solid you can create a punch feature tool, so refer to the documentation page you may find the way on how to create a punch feature tool.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
