iFeature, change affected SurfaceBody
cdellea
cdellea
Hi all,
I am trying to change, with VBA code, the affected bodies of an iFeature :
Sub ChangeiFeatureAffectedBody()
    Dim oDef As PartComponentDefinition
    Set oDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oBody As SurfaceBody, oBodies As ObjectCollection
    Set oBodies = ThisApplication.TransientObjects.CreateObjectCollection
    Call oBodies.Add(oDef.SurfaceBodies(2)) '<-- change with 1 or 2
    Dim oiFeature As iFeature
    Set oiFeature = oDef.Features("TROU_SERTISSAGE:1")
    Call oiFeature.SetAffectedBodies(oBodies)
    Call ThisApplication.ActiveDocument.Update
End Sub
Even if this piece of code is correctly executed (no exception), the affected bodies of the iFeature does not change. Do you have any idea of what's going wrong ?
In attachment, you will find a part made of 2 solid bodies. It contains as well an iFeature and the VBA code. The iFeature should create a hole. As it is configured in the part, no hole is created because the selection (solid selected does not match with the point and the plane selected), but this is on purpose. So, changing the affected surface body with the VBA code should make the hole "appear" (as then the selected body does match the point and the plane). But this is not working.
After running the VBA code, if I look with a spy the iFeature object, I can see that the "SurfaceBodies" property of the object does not change. It stills contains the same solid body as before the code is run.
Any help would be much appreciated.
Thank you,
Colin
andy
Did you find a solution for this? I'm struggling with the same issue
Andy
cdellea
Hi Andy,
Unfortunately, I havent found any way of making this working. I submitted a support request to ADN (Autodesk developer network) and they admitted this is a "bug" in the API.
For your information, change request as been recorded by Autodesk :
The Change Request for this is: ID:INVGEN - 58260 - "18360765 - Setting affected bodies to iFeature through Inventor API".
Cheers,
Colin
JelteDeJong
There might be a workaround by hiding all bodies except the one that is affected. Have a look at this thread.
Jelte de Jong
Blog: hjalte.nl - github.com
cdellea
Thank you very much for your answer.
Unfortunately, this project was abandoned due to the limitation / bug. So I wont be able to test and validate your proposition (even if it seems working).
