iFactory Part using iLogic
Hello Everyone,
I have been combining through the forums trying to figure out the best way to make a huge catalog of hardware without using Vault or content center. Originally, my thoughts were that an iFactory would work but found out that we need the properties still in the child parts. Then I read someone suggestion a solution to do an iLogic iFactory part. So far I have been able to get the parameters to update from an excel and save the separate files. This all seemed to easy and of course I was right, none of the parameters were saving with the separate files. I tired separating the rules and that didn't work. Anyways, I've hit a fence so any help will be greatly appreciated. Thanks for your time.
'Define Range
oStartRow = 1
oEndRow = 3
Dim o As Integer
For o = oStartRow To oEndRow
Dim i As Integer
i = i + 1
iProperties.Value("Project", "Description")=GoExcel.CellValue(EXCEL_LINK,"Sheet1","A" & i)
DIA=GoExcel.CellValue(EXCEL_LINK,"Sheet1","C" & i)
LEGNTH=GoExcel.CellValue(EXCEL_LINK,"Sheet1","D" & i)
MATERIAL=GoExcel.CellValue(EXCEL_LINK,"Sheet1","E" & i)
PART_CODE=GoExcel.CellValue(EXCEL_LINK,"Sheet1","B" & i)
FILE_NAME=PART_CODE & ".ipt"
ThisApplication.ActiveDocument.update
'iLogicVb.RunRule("FileCreate")
MsgBox("Diameter =" & DIA & vbCrLf &
"Legnth=" & LEGNTH & vbCrLf &
"Material ="& MATERIAL & vbCrLf &
"Part Code ="& PART_CODE)
File Creation
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim FName As String = oDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)'Dim oPath As String = Left(FName, FNP)
Dim oNewName As String = PART_CODE
Dim oType As String
Select Case oDoc.DocumentType
Case kPartDocumentObject:     oType = ".ipt"
Case kAssemblyDocumentObject: oType = ".iam"
Case kDrawingDocumentObject:  oType = ".idw"
End Select
oDoc.SaveAs(oPath & oNewName & oType, True)
Next
HermJan.Otterman
Hello Truc.Quach
keep in mind:
iParts and iAssemblies have some limitations. max 1000 rows
and they will get slow.
Excel makes is slow
how large will your catalog be??
only parts? or also assemblies?
how do you keep track of all those files without Vault?
iparts are linked to there mother, the advantage of CC is that they are not.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Hey Herm,
the current part I am doing is about 6,400 parts but I can also split this part into separate excel files if it gets too slow. We have a own tracking system that this will integrate to, but it needs all the unique parts generate and uploaded into it.
By generating the part through code and parameters it is still consider an iPart?
The goal I am trying to achieve is too create all 6,400 parts as if I were to go in create them all by hand one by one without actually doing that lol.
HermJan.Otterman
do they all look the same?
with iParts, they will be derived from a master, and that link wil be there.
how many dimensions wil change?
do you have all variations in an excel file (dimensions?)
Herm Jan
right now its just a bolt and the diameter, length, material, and part code changes.
Once this is figure out I will have to apply it to washers and nuts.
HermJan.Otterman
Why?? they ar all in the content center..? just add you number
Herm Jan
We have our own program that we have to integrate all the hardware to.
I ended up figuring a solution and will put it here in case anyone else ever has the same issue.
create two separate codes
one to pull in the excel data and update the parameters of the part
one to update and save the file
create a separate API that runs the first code, then the second code, and updates the excel row call out.
