idw to PDF
idw to PDF
Message 1 of 8
idw to PDF
Hi friends
I had problem that Printing Idw File to pdf.
i have one code which below run successfully, but when i open this pdf file error occurs that
"File extension is not correct or file is corrupted."
can anyone help why this happened
thanks in advance.
Private Sub PrintidwAsPdf()
If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
Dim oDrgDoc As DrawingDocument
Set oDrgDoc = ThisApplication.ActiveDocument
Dim oDrgPrintMgr As DrawingPrintManager
Set oDrgPrintMgr = oDrgDoc.PrintManager
Dim drawingname As String
drawingname = ThisApplication.ActiveDocument.DisplayName
' Remove file extension
drgnameno = Len(drawingname)
drgname = Left(drawingname, drgnameno - 4)
oDrgPrintMgr.Printer = "cutePDF Writer"
' Get the name of the printer that will be used if not pdf
If MsgBox("Inventor will now use """ & oDrgPrintMgr.Printer & """ to create a pdf of """ & drgname & """ ", vbYesNo + vbQuestion) = vbNo Then
Exit Sub
oDrgPrintMgr.ColorMode = kPrintColorPalette
oDrgPrintMgr.NumberOfCopies = 1
oDrgPrintMgr.Orientation = kLandscapeOrientation
oDrgPrintMgr.PaperSize = kPaperSizeA4
oDrgPrintMgr.PrintRange = kPrintAllSheets
oDrgPrintMgr.ScaleMode = kPrintBestFitScale
Dim pdf_pathname As String
pdf_pathname ="C:\" & drgname & ".pdf"
' Save as filename
oDrgPrintMgr.PrintToFile pdf_pathname
End Sub
Replies (7)
Message 2 of 8
Hi.
Did you find a solution.
I've got the same problem.
BE WELL
Message 3 of 8
Hi.
Marcus
Message 4 of 8
Well I changed your "cutePDF Writer" with my "Win2PDF" and all worked perfect! Sounds like there's something up with your writer.
Wayne
Message 5 of 8
Well its working fine with my "PDF995"
but when I try to open the created pdf it is saying that the file is corrupted.
Message 6 of 8
Creates corrupted PDF with Adobe PDF Writer (comes with Acrobat 7).
Tried Win2PDF and it worked... That makes three that do not work and one that does...
Message 7 of 8
I believe the error is in the PrintToFile method of the DrawingPrintManager. Try using the SubmitPrint method instead.
AFAIK, the PrintToFile method will create a PostScript file, but you have given it a .pdf extension (which creates a "corrupted" file because it is not pdf data). Message was edited by: Josh_Petitt
Message 8 of 8
I think this is true... I use distiller to create the pss file and then create the PDF.
