idw to dwf single sheet
Message 1 of 1
I can't seem to plot a single sheet, named or range via Inventor API. I have tried all possible settings (). PDF turns out fine, but DWFx is consistently wrong.
nothing I put here works
 options.Value("Publish_All_Sheets") = 0
 options.Value("Custom_Begin_Sheet") = 2
 options.Value("Custom_End_Sheet") = 2
 options.Value("Publish_Mode") = 62722
 options.Value("Sheet_Range") = 14083
Publish_mode = 62721,62722 or 62723, Sheet_Range= 14081, 14082 or 14083.
Tried to add
Public Sub GetTranslatorSaveAsOptions()
    ' Using GUID of the DWF Translator
    Dim mApp As Inventor.Application
    Set mApp = ThisApplication
    Dim clsId As String
    clsId = "{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}"
   Dim clsIdDwfx As String
    clsIdDwfx = "{0AC6FD97-2F4D-42CE-8BE0-8AEA580399E4}"
    Dim oTranslator As TranslatorAddIn
    Set oTranslator = mApp.ApplicationAddIns.ItemById(clsId)
     Dim oTranslatorDwfx As TranslatorAddIn
    Set oTranslatorDwfx = mApp.ApplicationAddIns.ItemById(clsIdDwfx)
    Dim context As TranslationContext
    Set context = mApp.TransientObjects.CreateTranslationContext
    context.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim options As NameValueMap
    Set options = mApp.TransientObjects.CreateNameValueMap
    Dim SourceObject As Object
    Set SourceObject = mApp.ActiveDocument
 Dim oData As Inventor.DataMedium
 Set oData = mApp.TransientObjects.CreateDataMedium
 oData.FileName = "c:\temp\file2.pdf"
Dim oDatadwfx As Inventor.DataMedium
 Set oDatadwfx = mApp.TransientObjects.CreateDataMedium
 oDatadwfx.FileName = "c:\temp\file2.dwfx"
 Call oTranslator.SaveCopyAs(SourceObject, context, options, oData)
Call oTranslatorDwfx.SaveCopyAs(SourceObject, context, options, oDatadwfx)
    Dim index As Integer
    If oTranslator.HasSaveCopyAsOptions _
        (SourceObject, context, options) Then
        On Error Resume Next
        For index = 1 To options.Count
            Debug.Print (options.Name(index) & " = " & options.Value(options.Name(index)))
        Next
        On Error GoTo 0
End Sub
tried to add this, but no difference.
    Dim oSheets As Inventor.NameValueMap
    Set oSheets = ThisApplication.TransientObjects.CreateNameValueMap
    Dim oSheet1Options As Inventor.NameValueMap
    Set oSheet1Options = ThisApplication.TransientObjects.CreateNameValueMap
    oSheet1Options.Add "Name", "dwfx:2"
    oSheets.Value("Sheet1") = oSheet1Options
    options.Value("Sheets") = oSheets
Replies (0)
