idw PDF creation on save
I am wanting to save a PDF of an idw in Vault automatically.
I got this code from a link that works for saving the idw as a PDF in the folder shown V:\Vault\Designs\Stock Items\PDF
This code saves the idw as the file name e.g.. PDFBA1234.
Part Information:
The ipt & idw are BA1234.
I am wanting to use the information from the iproperties 'Project tab' part number which is this number BM5678.
If possible I would also like to save the PDFs with the idw in the same folder. Folder structure is below
Stock Items
-BA
-BB
-BC
etc
Can anyone help?
strFolder = "V:\Vault\Designs\Stock Items\PDF" & ThisDoc.FileName(False) 'without extension
ThisDoc.Document.SaveAs(strFolder & (".pdf") , True)
MessageBox.Show("All file formats saved", "File Save")
I have got the iproperties value to sort of work now but it only names the PDF as 'B'.
I want it to use the whole name BM-0200....... etc
Can anyone help?
strFolder = "V:\Vault\Designs\Stock Items\PDF\" & iProperties.Value("Project", "Part Number")(False) 'without extension
MessageBox.Show("PDF Created", "File Save")
so are you wanting the user to choose which folder (BA, BB, etc) or are you wanting that to come from the first 2 letters of the Part Number?
This gets it to the PDF folder with the file name set to the Part Number. (the False was resulting in just B):
This saves the file to the folder that matches the first two letters of the Part Number property. For instance, if the Part# = BM5678
then the path = V:\Vault\Designs\Stock Items\PDF\BM
and the file name = BM5678.pdf
if the folder doesn't exist it doesn't work.
strFolder = iProperties.Value("Project", "Part Number")
strTrim = Left(strFolder,2)
strPath = "V:\Vault\Designs\Stock Items\PDF\" & strTrim & "\" &  iProperties.Value("Project", "Part Number")
ThisDoc.Document.SaveAs(strPath &(".pdf") , True)
