*idw part visibility
I am looking for some pointers on where to start on finding Browser nodes in an *.idw. Do I need to select the view first then sort throught the nodes to find a part match..? Basically I am looking to write some vba code to turn part visibility on and off. Trying to find the part in the browser and then RMB to turn off visibility is getting old..
wayne
You need to use the DrawingView.SetVisibility
method. In your case, the first input argument to the method should be a
specific ComponentOccurrence object that you obtain from the assembly referenced
by the drawing view.
Sanjay-
Thanks Sanjay, works like a charm!!
Wayne
